Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Unread 18-01-2004, 13:58
Pamela's Avatar
Pamela Pamela is offline
Half the JVN,All theTaste
Pamela has a spectacular aura aboutPamela has a spectacular aura aboutPamela has a spectacular aura about
Send a message via AIM to Pamela
Re: Removing Bosch Drill Pins - Cause of Failure?
Originally Posted by Mike Rozar
Does anyone know where we can get some drawings for the output shaft and the other parts you have to make when you get rid of the the back drive pins????
We have some people to help the students machine these but maybe not design them.
Can you buy them???
Please help....
Mike-
You don't need to manufacture any new parts on account of taking out the pins from the drill trannys, they run beautifully unmodified after removing the pins.
~Pamela, Alumni of 166 and 229
Unread 19-01-2004, 00:16
Mike Rozar's Avatar
Mike Rozar Mike Rozar is offline
FRC #0547 (F.E.A.R (Falcon Engineering And Robotics))
Mike Rozar is an unknown quantity at this point
Originally Posted by Pamela
Mike-
Pamela,
Thats good news. The last slide in the powerpoint pres on the FIRST site said make a new shaft, etc.
Am I correct that there are only two pins?[IMG]http://[/IMG]
Mike
Mike Rozar, Engineer & Mentor
Team F.E.A.R. 547
2001 VCU Rookie All Star
2001 National Rookie All Star
2002 KSC Delphi Driving Tomorrows Technolgy
2002 Newton Quarter Finalist
2003 St. Louis GM Industrial Design
2003 Archimedes Finalist (47, 201, 547)
2004 St. Louis Chairman's Award
2005 Gret Lakes Judges Award
2006 St. Louis Winner (547, 71, 537)
...and the journey continues
Unread 19-01-2004, 00:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
yes, there are indeed 2 pins. Dr. Joe recommended a new shaft so that it wasnt threaded., making it easier to couple to another shaft, or mount a sprocket on.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 19-01-2004, 02:00
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Pamela,
Mike
That PowerPoint slide set was assembled based on the assumption that you wanted to replace a major portion of the standard Bosch gearbox (ie. with a modified "Dr. Joe's Output Shaft" or similar device). If you are just removing the anti-backdrive pins, then you can stop after Slide #4.
-dave
Unread 19-01-2004, 02:04
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We took ours out today. We were following the PowerPoint to the pixel and started to pull off other parts until we realized "hey, we already got the pins out, we're done!" Hehe. Anyway, it is an extremely easy procedure if you are careful. I can't wait to try them in the new "QuadraMax G2"
Unread 19-01-2004, 07:33
Does anyone know where we can get some drawings for the output shaft and the other parts you have to make when you get rid of the the back drive pins???? Please share if you can.....
Can you buy them???
Please help....
Mike,
If or when you remove the pins there is no change in the output shaft. You can still use the supplied hardware to make a drive system. The output shaft of the supplied drill tranmission has a standard drill chuck termination with a left handed thread and a locking screw just like all drills. Teams that are new to this arrangment should remember to use that locking screw and be sure it is tight before final assembly.
Unread 19-01-2004, 22:52
Mike Rozar's Avatar
Thanks to everyone for clearing this up. We will be taking them out.
Team F.E.A.R. 547
Unread 20-01-2004, 00:13
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Ahhhhhh... THAT'S the problem!!!!
We too, had the problem of the clutch slipping after having removed the pins. Al Skierkiewicz, thank you. I was losing my mind, having rebuilt that gearbox three times.
Here's another possible issue to contend with. We had treads last year and when we wanted to dead-recon turn by stopping one tread and continuing forward with the other, the bot had so little resistance on the stopped side (no backwalk pins) that it continued to roll forward and not turn at all. We had to actually change the program from 127 to 115 on the stopped side. Is there an easier way which we overlooked?
Unread 20-01-2004, 00:32
I'm not sure how much "stopping force" it provides but don't forget about the brake jumper on the speed control.
Unread 20-01-2004, 07:21
Kevin,
I think what you were up against is the extreme friction produced by tank treads. Even with the speed controllers set to brake, there is not enough force to hold back the non-moving side. You have to visualize the transfer of forces as the robot tries to turn and that the treads are trying to slide sideways as well. Tank treads are OK for certain games but they are bad if you want manuerverability and low current demand. If you look at the Innovation First site I think they still have a paper showing the currents generated by different drive systems. You can't stop a tank but you can't turn it on carpet either.
Bosch Drill Motor rmmlg Inventor 7 17-12-2003 14:33
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Bosch Drill Motor CAD Files Madison Inventor 10 09-12-2001 00:14
