Go to Post Go figure that by teaching you end up learning a lot through the process. ;) - Josh Fox [more]
Unread 16-01-2004, 08:24
Change in Kit Primary Battery
Hello All,
Our electrical team began last night with attaching #6 wire and disconnects to the new kit batteries. In comparison to last year's battery, the terminals are now positioned at the outside edge of the battery. This puts them in a vulnerable spot both electrically and mechanically. Please be aware that clearances in your battery holder in the robot may compromise the battery terminals. Be sure to insulate the terminals. If you use the supplied hardware, I recommend that the head of the screw face the outside of the battery and the wire terminal, nut and any other hardware face the inside of the battery to maintain maximum clearance at the battery edge.
Remember a fully charged battery is capable of producing currents high enough to weld with.
Unread 18-01-2004, 05:04
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
Re: Change in Kit Primary Battery
Originally Posted by Al Skierkiewicz
Hello All,
ya, and if your team is super poor / ghetto as ours is, you can use the battery to spot weld (thin stuff)
Unread 18-01-2004, 09:14
Lord Nerd,
I hope you are just joking about this. Sustained shorts across the battery can lead to high temperatures in the battery. This results in a deformed case or explosion. In other words,
Don't Short the Battery!
Unread 18-01-2004, 10:11
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
When you say outside edge, I'm assuming you mean side post terminals instead of top post? If you are, it really should not make a difference, considering you just have possibly a half inch less space to place with when designing the battery holder.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 19-01-2004, 07:22
Pras,
The top terminals are very near the outside edge of the battery compared to all past batteries. The spec sheet does not reflect what was delivered. The flat side of the terminal is about 3/16" from the outside edge of the short sides of the battery. If you use the supplied hardware to attach a terminal and place the nut on the outside ist will overhang the outside edge of the battery by as much as 1/4". I feel this is a risk for shorting in robot frame and physical damage should the hardware catch on robot structures during insertion or removal.
Jump Start RC w/o Exide 12v battery Mark McLeod Control System 3 12-01-2004 12:42
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
