Go to Post This is definitely the best FRC parody of an FRC parody I have seen. - Jared Russell [more]
Unread 19-01-2004, 09:50
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
yet another joystick question
due to both being right handed, I was wondering if we're allowed to get new ones, as long as they're 2 axis same button type of joysticks? I'm hoping to go for a left/right neutral type, will this be allowed?
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 19-01-2004, 09:54
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: yet another joystick question
You can use pretty much any joystick that uses the old PC gameport (DB15) style connector. FIRST doesn't seem to care what's hooked up to the OI as long as it meets all the specifications given by Innovation First. However, IFI makes it pretty clear that if you use your own controls, then you're doing so at your own risk.
Unread 19-01-2004, 10:10
cs2105 cs2105 is offline
Location: east hartford, manchester, coventry, rockville
cs2105 has a little shameless behaviour in the past
Send a message via AIM to cs2105 Send a message via Yahoo to cs2105
Does anyone know if we are allowed to purchase additional servo motors and use them at the same time as those we were supplied with by the kit?
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
Alternate Joystick question archiver 2001 5 24-06-2002 00:01
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
