My love spiders out in a web of emotions when I think of you.
Unread 19-01-2004, 10:37
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
digital i/o connectors
I've been trying to buy some connectors for the digital I/Os on the RC, like the ones with the red, white, and black wires that came in the Edu kit. The only problem is that I can't find them at any stores, and I don't know what they're called! I was thinking about ordering some PWM extender cables from InnovationFirst and just ignoring the fourth wire, but buying them from a store would be a lot faster and probably cheaper. If you could tell me where to look for them, or even just what they're called, I would love you forever! An alternate way to connect to the digital I/Os would work too.
~Aaron
:grovel grovel:
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 19-01-2004, 12:00
Electrical Engineer
Rookie Year: 1995
Re: digital i/o connectors
~Aaron
:grovel grovel:
Aaron,
You want the 3 wire pwm extension cables which you can purchase from any hobby store that sells RC airplanes, cars, etc. You can also buy online from Tower Hobbies.
In addition, do a search of these fori as there have been threads dealing with buying the connectors from Digi-key and making your own...
We use the PWM extension cables... It's easier.
Mike Betts
As easy as 355/113...
Unread 19-01-2004, 12:26
#1213 (The Grobots)
Thanks, Mike! I'd been looking mostly in computer/electronics stores... hadn't thought to try a hobby shop. Your help is much appreciated!!!!!!!
—Albert Einstein
Unread 19-01-2004, 16:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can buy the wire here http://www.servocity.com/html/servo_wire.html but you still need to get the pins and connectors.
Unread 19-01-2004, 19:20
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
3 Pin Connectors:
Digikey WM2801-ND
$.72 ea
min order: 1
Crimp pins:
WM2510-ND for Tin plating, 22-24 AWG (for different guage or gold plating, check the catalogue)
price: .90 for 10
min order: 10
Since I was looking for these myself today, I'll also post another useful connector I found today (again, Digikey part numbers). You know those snapping/locking 4-pin connectors used in computers?
Molex Conn - Recep A1402-ND
Molex Conn - Plug A1403-ND
For housings with different numbers of pins, check the catalogue
Molex Conn - Pin A1422-ND
Molex Conn - Socket A1423-ND
[Edit]
I say this almost every time I post Digikey p/n's, but again: if your order is less than $25, Digikey taks on a $5 handling fee. My suggestion is figure out all the Digikey stuff your team needs (shrink wrap, wire ties, velcro straps, extra OI ac adapters (they get lost), fastons/spades/ring connectors, breadboards, etc.) and put together a central Digikey order.
[Edit Edit]
If anyone on your team has those cool little LED keychain raving lights, the part number for a CR2016 coin battery is P138-ND. From Digikey, they're $.405 ea. Radioshack or any other pharmacy: ~$3. Stock up for those late-night lightswitch rave parties. 'Nuff said.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
