Go to Post So, the game hint is there is no game hint. - tindleroot [more]
Unread 18-01-2004, 14:15
Atheist Atheist is offline
Atheist is on a distinguished road
IR Receivers mounting
Where do you guys plan on mounting the IR receivers? Specifically at what height? I don't see the height of the beacons specified anywhere in the manual.
Unread 18-01-2004, 14:28
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: IR Receivers mounting
Fourty-four inches is the height of the beacon LEDs (please double check this). Don't go above this height because the beacon housing blocks emissions above this height (to minimize reflections).
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2004, 14:42
I assume that we shouldnt go belove it either??? Anyone else know if 44 inches is correct?
Unread 19-01-2004, 11:29
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Hey Atheist,
We built an IR beacon without a housing and raised it 44 inches above ground. We placed our receiver at ground level, and received signals down to 2 feet (on the ground) away from the beacon. Any closer and it got a little sketchy.
Both the receiver and beacon LEDs were aligned to point parallel to the ground.
The LEDs and receiver both seem to have pretty good spread, so you should have a fair bit of flexibility on your mounting height.
I was a little worried at first about mounting height, but once we got it working, I wasn't so concerned.
Fischer Price mounting screw ateene Motors 1 09-02-2003 21:00
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
Sideways mounting srjjs Electrical 13 25-01-2003 20:31
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
Wheel mounting Moshingkow Technical Discussion 15 09-10-2002 19:25
