Re: digital i/o connectors
Thanks, Mike! I'd been looking mostly in computer/electronics stores... hadn't thought to try a hobby shop. Your help is much appreciated!!!!!!!
You can buy the wire here http://www.servocity.com/html/servo_wire.html but you still need to get the pins and connectors.
3 Pin Connectors:
Digikey WM2801-ND $.72 ea min order: 1 Crimp pins: WM2510-ND for Tin plating, 22-24 AWG (for different guage or gold plating, check the catalogue) price: .90 for 10 min order: 10 Since I was looking for these myself today, I'll also post another useful connector I found today (again, Digikey part numbers). You know those snapping/locking 4-pin connectors used in computers? Molex Conn - Recep A1402-ND Molex Conn - Plug A1403-ND For housings with different numbers of pins, check the catalogue Molex Conn - Pin A1422-ND Molex Conn - Socket A1423-ND [Edit] I say this almost every time I post Digikey p/n's, but again: if your order is less than $25, Digikey taks on a $5 handling fee. My suggestion is figure out all the Digikey stuff your team needs (shrink wrap, wire ties, velcro straps, extra OI ac adapters (they get lost), fastons/spades/ring connectors, breadboards, etc.) and put together a central Digikey order. [Edit Edit] If anyone on your team has those cool little LED keychain raving lights, the part number for a CR2016 coin battery is P138-ND. From Digikey, they're $.405 ea. Radioshack or any other pharmacy: ~$3. Stock up for those late-night lightswitch rave parties. 'Nuff said. Last edited by DanL : 19-01-2004 at 19:29. |
| Slip connectors (custom electrical connectors) | Damian Manda | Electrical | 2 | 08-02-2003 17:53 |
| Diagrams for wiring of 15 and 25 pin connectors | archiver | 2000 | 2 | 23-06-2002 23:03 |
| making speed controller digital | CharlieWilken | Electrical | 4 | 01-03-2002 20:15 |
| RJ-45 connectors, DB25 connectors and the like: legal or no? | Andrew Wyatt | Technical Discussion | 6 | 04-01-2002 22:53 |
| 45 or 75 amp anderson power products connectors to drill motors? | Andrew Wyatt | Motors | 2 | 20-12-2001 08:00 |
