Go to Post We score 8 out of 10 every match. Oh wait, that's just what it does in theory. ;) Man, I wish that theory worked. - Chriszuma [more]
Unread 19-01-2004, 15:00
tchescow's Avatar
tchescow tchescow is offline
out of control
AKA: Gianfrancesco Venturin
#1156 (Under Control)
tchescow is on a distinguished road
Send a message via ICQ to tchescow Send a message via MSN to tchescow
Drill motor gear
How do we do to prevent the drill motor gear from "falling" ? As we were testing our chassi proto, if the acceleration was too high the gear would just desengage. Any ideas?
C ya! Tchescow!
Under Control - #1156 - Brazil
2005 NJ Engineering Inspiration Award
2004 J&J Mid-Atlantic Judges Award
2003 J&J Mid-Atlantic Rookie All-Star
http://www.undercontrol.com.br
A little inaccuracy sometimes saves tons of explanation.
Saki, "The Square Egg", 1924
Unread 19-01-2004, 15:20
REVving up for a new season
FRC #2848 (All-sparks)
Re: Drill motor gear
i am not sure exactly to what you are refering to but here are my two best guesses
1) you need to fascen the shifter in one direction or another, FIRST provided rubber bands for this this year but i would sugest hose clamps both should do just fine
2) if you have not put in the left handed thread screw to the alumium block to the tranny then it will unscrew and fall off. the left handed screws are in the drive train bag each in seprate sealed plastic bags. once you put the alum hex block on then put the screws in backwards.
___________
|___________--| <------screw goes in this way
Unread 20-01-2004, 07:48
Pâzinha's Avatar
Pâzinha Pâzinha is offline
AKA: Pamella
Team Role: Student
Pâzinha is an unknown quantity at this point
Send a message via ICQ to Pâzinha Send a message via MSN to Pâzinha
what is "hose clamps" and in what bag did it co me? thanks!!
Unread 20-01-2004, 07:49
Pâzinha's Avatar
AKA: Pamella
Team Role: Student
what is "hose clamps" and in what bag did it come? thanks!!
Unread 20-01-2004, 08:41
hose clamps arn;t in the kit they are a standard plumbing suppy used for attaching rubber hose where you can tighten them (see the picture below)... if you don;t have any just use the rubber bands that are in the kit and you should be fine
Unread 20-01-2004, 13:54
tchescow's Avatar
out of control
Got it... the problem is solved now! the guys were forgeting something... I really don't know what exactly, it was that backwards stuff... anyway, thanks a lot
C ya! Tchescow!
Unread 25-01-2004, 21:56
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
If you are trying to keep the drill transmission in low gear, just unsnap the black plactic unit on the back of the transmission where the motor slides in. Rotate the removed unit 180 degrees and reinstall. The black plactic unit is assymetrical and when you turn it around, a plastic flange on the unit will prevent the transmission from going out of low gear.
Ralph
Unread 25-01-2004, 23:14
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
aye, that's what we did to lock in the drill motors into low gear. last year we had crazy problems with the shifter drifting into nuetral and...need I say more. The rubber bands can work if they are applied properly but that can be difficult.
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
