Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 19-01-2004, 15:37
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Process Destroying (C++)
I'm writing a Process Destroyer for Windows XP Home Edition, and have ran into a problem that hopefully someone can help me out with.
I've got the program destroying 9/10th's of the process' I ask it to destroy perfectly, except one. That one is Kazaa. Is there something in Kazaa that stops other programs from destroying it or something?
You maybe (and probably are) thinking, "Gee genius, why not just remove it from your compter???" The reason being is because someone else who uses this computer keeps installing it again (I've uninstalled it so many times). If someone can think of why Kazaa won't be destroyed, please tell me.
(PS: Before this becomes a possible flame war, I asked Brandon ahead of time to make sure that asking this would be cool, and he said Ok)
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 19-01-2004, 15:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Process Destroying (C++)
Hmmm... My school created something in VB6 Called 'Omega', And it kills applications on its 'blacklist'. Kazaa is probably on it.
Try Ctrl-Alt-Delete-ing it and see what happens. If it doesn't respond there's a good reason: IT JUST WON'T UNLOAD. If it unloads ok but comes back, it runs itself again before unloading.
One Idea: Replace the Kazaa exe with a dummy and lock out the download site.
Unread 19-01-2004, 15:47
AKA: Eric Hansen
C-A-D'ing it works, and it doesn't repopulate after destroying it that way.
Ok, not to sound dumb, but what exactly do you mean by locking out the download site??
[Sorry, overload of mid-term stress is just leaving my system...:|]
Y!: synsoflife
Unread 19-01-2004, 15:54
AKA: Jamie Bliss
It's OK. In IE, go to Tools>Internet Options... In the dialog box that comes up, go to the 'Security' tab, and add it to the 'restricted sites' list.
Check MSDN (www.msdn.com) about it.
Unread 19-01-2004, 16:01
AKA: Eric Hansen
Ok, thanks. I will do that.
Y!: synsoflife
Unread 19-01-2004, 18:30
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
and if they know enough to go and take it off the list, you could look up using the windows HOSTS file to redirect the domain to a different site (such as localhost).
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 19-01-2004, 18:43
AKA: Eric Hansen
True. Or, do both to be on the safe side
Y!: synsoflife
Unread 19-01-2004, 18:49
Bharat Nain's Avatar
Kazaa is the worst software one can long for. Including Kazaa Lite. I tried de-bugging both the softwares, as I had run into a similar program. THOSE THINGS ARE IMPOSSIBLE . Kazaa is a total non-sense and as for Kazaa Lite, since its totally anti-Kazaa, it even blocks us from accessing certain sites. Also it plays around with IE(Kazaa and Kazaa Lite), to restrict access on your computer almost permanently. So we just gotta be careful with these things. Do as he said, hopefully it helps
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 19-01-2004, 18:59
Umm Errr...
I wrote an application once that required the killing of other processes. Be aware that there are several levels of killing proceses and child proceses. Try a higher one.
They range from the humble: "excuse me sir, would you please close when you find time if it does not inconvenience you in any way"
To: "you will be terminated now! resistance is futile. die @#$%^ die!"
There is an api call for each. With some research i'm sure you canfind them.
1139 Alumni
Unread 19-01-2004, 20:47
AKA: Eric Hansen
Ok, thank you. I know there's 4-5 priorities (with the highest being the most dangerous also). I'll search MSDN when I get chance.
Techno: I personally hate all P2P programs. Kazaa/lite just uses up to much resources (Kazaa uses 16,000 kb of memory w/o doing anything)
Y!: synsoflife
Planning Process Ravi U Chairman's Award 1 07-01-2004 18:12
Admissions Process for becoming a team member?? archiver 2001 18 24-06-2002 03:50
what is *your* process? archiver 2001 2 23-06-2002 22:19
