Go to Post Any metric you want to apply to Pink, they will pass with flying colors. Pun intended. - Lil' Lavery [more]
Unread 19-01-2004, 15:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How to turn down gear hubs?
How can I turn down and/or take off gear and sprocket hubs. I don't want to clamp on the teeth (at least not too hard) for risk of damaging them. How should I go about this?
Unread 19-01-2004, 16:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: How to turn down gear hubs?
Mill the hub off.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-01-2004, 16:55
Woudl I just lightly clamp it in a vise? Maybe with some lead jaw covers? That works good for facing off or removing the hub, what if I want to turn it down (remove diameter)?
Unread 19-01-2004, 16:59
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Take some small pieces of cloth, and put them inbetween the Gear and the chuck jaws. This was the gear teeth do not get scrached.
-Aaron
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 19-01-2004, 17:38
Jimmy Holmes Jimmy Holmes is offline
It's not all about the robots
FRC #0027 (Team Rush)
Jimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of lightJimmy Holmes is a glorious beacon of light
Drill a couple of holes into the sprocket and screw it to a plate that has the same hole patteren as the sprocket and then clamp the piece to the mill. You could also try the same method with a lathe. The sprocket holder would just have to have a rod to go into the jaws of the lathe. Just some thoughts, I hope it helps, good luck
Unread 19-01-2004, 18:24
REVving up for a new season
FRC #2848 (All-sparks)
if you have acess to a lathe you can run a shaft through the center (mount the sprocket) and then use that in the jaws of your lathe then you can turn it to what ever dimentions you want.
Unread 19-01-2004, 19:21
Matt Reiland's Avatar
'The' drive behind the drive
Sanddrag,
Last year I attached the hub to a shaft with a trantorque then milled it down. The trantorque kept the hub perfectly centered and you can reuse it over and over.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 19-01-2004, 19:32
Originally Posted by Matt Reiland
Sanddrag,
What is a trantorque? Is it something a well equpped machine shop would have? Google Image search didn't give me too much. Thanks.
Unread 19-01-2004, 19:56
Quick-Mount Keyless Bushings Since there are no keys, cap screws, or other components to slow you down, you can torque up one of these bushings in just seconds. Match bushing OD to bore of your sprocket, pulley, or gear.
Each bushing has inner and outer sleeves. As you tighten the collar nut, the inner sleeve contracts onto the shaft while the outer sleeve expands to hold your component. Bushings accommodate shafts that are slightly out of round. They're quick and easy to install and remove.
Stainless steel bushings are made of Type 303 stainless steel.
THis is from McMaster, Small Parts also sells them
Unread 19-01-2004, 22:07
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
If I were going to take the hub off, I'd clamp it in a vise with aluminum inserts ("soft" jaws) so as to not damage the teeth. I'd think this would only work if you have an even number of teeth, though; I think it'd get shaky with an odd number (clamping down on 3 instead of 4 teeth).
If I was going to take the diameter of the hub down, I'd do one of two things. If I wanted to do it absolutely right, I'd do what someone else suggested and mount a keyed shaft in the lathe and mount the sprocket/gear. If I wanted it done faster and cleaner I'd mount the gear to a rotary table and take off the hub with a milling machine, or mount it to a CNC's vise and say "give me a small circle here"
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 19-01-2004, 22:37
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Here is how I saw an experienced machinist hold a sprocket in a vise last year: take some small pins (like maybe small dowel pins) and put them in between two teeth. Then you can clamp down on the pins, which transfers the force to the root of the tooth (which is much stronger than the tip of the tooth). Now that you have your sprocket clamped in your vise, just mill whatever you want.
/* Daniel */
Unread 20-01-2004, 01:21
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
Last year I wanted to take the hub off a gear so I clamped it in a vice and attacked it with an angle grinder. --Not a joke--
Unread 20-01-2004, 09:10
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Also, on most sprockets that i have seen of more than around 2.5" diameter or so, they were made by welding an hub to a hubless sprocket blank, if you look closely and see a weld bead at the hub/sprocket interface on the outside of the hub try just cutting that out with your lathe, for us the hub would then just drop right off.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
simple engineering question Ben Mitchell Technical Discussion 2 07-11-2001 07:50
