Go to Post We make ourselves better by lifting others and standing on their shoulders, not by knocking them down. - Taylor [more]
Unread 19-01-2004, 16:59
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Using Reactor...
Well, I don't even know where to start, but I do know that after animating container after container last year that I don't wanna do it again. For the balls this year, how do you use reactor to model some real-life movements??
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 19-01-2004, 18:17
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: Using Reactor...
you have to use reactor, but you already knew that. to set up the process, you must first add a ridgid body collection to the scene, under the modify tab, add the objects you want to be simulated, including stationary objects. u may choose to add a reactor plane to the scene, but having a regular plane added to the ridgid body collection works well too. after you have added all the objects, go the utility tab and select reactor. under properties there should be a mass input box. 0 kgs is the default setting and indicates that the object is stationary. for concave objects, you will be required to use to change simulation geometry. once you have all this, go to hte preveiw & animation menu and hit create animation.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 19-01-2004, 21:40
FRC #0701 (RoboVikes)
read the book that comes with max...it isn't really that hard....i know that "isn't helpful" but thats probably easier.. and will give you more info
Team 701
Unread 19-01-2004, 21:44
Eric Rowe
i agree, and would add that for the whole of max, the documentation is great, use it!
Eric Rowe | Alumn
Unread 19-01-2004, 22:26
Alright, will do, I was mainly creating a thread for people in the future that come to the chief forums looking for help with Reactor. Cause in all honesty, it's not something very many people use... and it's complicated at first glance.
Unread 20-01-2004, 08:42
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Be careful about the complexity of the object you are trying to group as, a "Rigid body."
Lead Animator for Donder-Kimball High School, team #1188.
Unread 20-01-2004, 10:46
ditto....i tried to simulate a planetary gearing system....it TOTALLY froze a dual Xeon 1gig ram system.....
and really...the manual isn't that complex...you can simulate balls bouncing in like 25 min
Team 701
Unread 20-01-2004, 15:09
kthx, your point has been made.
If anyone else has reactor tips for others, put them in this thread.
Unread 20-01-2004, 22:14
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
my team tried it for the bins last year but it didnt work as planned...the program has incredible potential if u can use it right. i no im repeating but the tutorials are a big help. especially the balls-in-a-bucket for this year.
Unread 26-01-2004, 19:18
Okay so how would I make an object hit another object...like how would I make it so the robot would drive up and knock the ball off the tee with real world dynamics?
Unread 26-01-2004, 19:45
u need to set the weights in the reactor property editor.. im not an expert, but if u have in ur animation a point in time where the planes of the 2 objetcs intersect, and u go to the reactor menu and click make animation, it will do out all the calculations and simulate it
Unread 26-01-2004, 22:21
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Create a spline. Have your robot follow that spline. Add a rigid body collection. Add the robot and whatever objects you want the robot to interact with. Set the weights. adjsut the friction and the other one.
i think that's the basic steps.
i have a question. Why do objects jump at the start of the scene after incorpating Reactor with the objects?
For example. a simpel scene:
i placed couple cubes in a room, i add them to my rigid body collection, i set a weight to like 20, and i hit Preview Animation. The havoc window comes up and i press P for play. The first thing i see is that the cubes jump up and then fall back down. How do i prevent this? Which setting is affecting the objects?
i have the scene animated, but my broadband provider has an upload limit and my quick render of the scene is past the limit (36,828 KB)
-kevin
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 27-01-2004, 00:24
Eric Rowe
i had the same problem, but only with the new reactor (the one that comes with 3dsmax 6) i think it might be a bug in the new program, but i still havent messed around with it enough to figure out how to fix it.
Eric Rowe | Alumn
Unread 27-01-2004, 15:33
The major causes of jumps and things like that I've found is if your objects "bounding box" or whatever you decided to use is clipping each other. I'll do some tests for you when I'm at school tomorrow.
Unread 27-01-2004, 23:41
Nero's Avatar
Nero Nero is offline
#1155 (SciBorgs)
Nero is an unknown quantity at this point
Send a message via AIM to Nero
I want to animate clothing around a character using reactor. It when i set the clothing as a "clothing" and the mesh of the character as a "rigid body", but it doesn't take into acount the animation of the rigid body (such as walking or moving arms etc). Any ideas how to get reactor to take into acount that?
Oh yeah! I'm born on National Techie Day!!!
Reactor Jack 3D Animation and Competition 3 04-05-2003 03:21
Help with reactor Funnyanimator 3D Animation and Competition 1 16-02-2003 14:22
Animating Falling Bins with Real World Dynamics mixmasta321 3D Animation and Competition 17 08-02-2003 22:44
Reactor poll Funkymunkey90 3D Animation and Competition 4 20-02-2002 23:10
Reactor software? Adrian Wong 3D Animation and Competition 4 15-01-2002 16:45
