Go to Post Amazing what you can find with a quick video and the unlimited power of the internet! - AveryLevin. [more]
Unread 19-01-2004, 18:34
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
How do we Test our Beacon and Sensor
We have completed the beacon and the sensor but I am not sure how to test and see if the two are correctly talking. We have uploaded the code into both the Edu controller and the ifi controller. What should the results be?
Matthew
Ubergeeks
Unread 19-01-2004, 19:23
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: How do we Test our Beacon and Sensor
Matthew
Ubergeeks
Try uploading the file in this .zip file to your robot controller. Once it's running, you should see a bunch of data dumped to the console window every second or so. This is the raw data in the sensor_stats arrays that you'll find documented in receiver.c/.h. As I haven't had a chance to test this code, please let me know whether it works or not. It would be most helpful if someone with a known good beacon and sensor(s) could try it out and report back.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2004, 19:58
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
-Kevin
Thanks, I will try this tommorrow when I get back in the shop.
Matthew
Unread 24-01-2004, 20:37
Lead Tyrannosau Lead Tyrannosau is offline
Lead Tyrannosaurus Trainer
#1272 (Tyrannikal Mechanikal)
Lead Tyrannosau is an unknown quantity at this point
You can test your IR beacon by looking at it through the viewing screen of a digital camera. The beacon will show up as white light. You may have to block or turn off the visible light to see it.
Unread 07-02-2004, 12:58
starfyter2 starfyter2 is offline
starfyter2 is an unknown quantity at this point
Question Re: How do we Test our Beacon and Sensor
We are also having problems testing our beacons. I also had the idea to try using a camcorder on night vision mode and a night vision monocular to see the IR light emitted from the beacon, but no luck. Our team was a bit confused from the earlier discussion about how the wiring diagram may have had a bad pinout for the FET. Our IR beacons are wired like shown in the wiring diagram in this document http://kevin.org/frc/Infrared_System_rev012704.pdf.
We tried to power these for testing with a power supply in the lab. We put ground to black (GND) and white (-) pins on the 3-pin connector, and aprox. 6 volts to the red (+) pin. Does this sound like it should work to anyone else? It looks as though we should eventually be connecting the beacons to the EDU RC pwm outputs? Is this true?
Unread 07-02-2004, 13:10
FRC #2429
Tie the white lead to the red (not black) lead and try it. This should be done with a +5 volt supply. Also, why aren't you just using the EDU-RC for this?
-Kevin
Kevin Watson
http://kevin.org
Unread 07-02-2004, 15:23
-Kevin
Thanks Kevin. So if I tie +5V to White and Red and ground to Black then the board should work? Do you have a suggestion on how test that our IR Beacons are working? Unfortunately, our EDU-RC is locked away in a room for the weekend - so we had to get creative in order to continue working.
Unread 07-02-2004, 15:42
FRC #2429
Yes, this should turn all four LEDs on. While on, you can then use your digital camera to see the LEDs. You'll need to hook it up to the EDU-RC to generate the beacon waveforms.
-Kevin
Kevin Watson
http://kevin.org
Official Beacon Tracking Code Posted Kevin Watson Programming 41 18-02-2004 21:04
IR sensor question Daniel Brim Programming 1 18-01-2004 14:35
Resolution of IR sensors Paul Marshall Technical Discussion 2 16-01-2004 14:03
An Example IR Beacon Tracking Assembly... Kevin Watson Electrical 0 14-01-2004 12:30
