Re: I-sprocket?
It doesn't work for me in 7 either.
I found the issue with I-Sprocket .......
It's posted in the First Cad Library. I've tested it under Inventor 5 & 6. If a few of you could please test this part with Inventor 7 and get back with me I would appreciate it. Big thanks to Daniel Wong for his assistance in tracking down the problem. PS. I've also posted the Grounding Terminal |
Re: I-sprocket?
Thanks Ed. It's working for me now.
-Daniel |
| If set screws suck . . . | Madison | Technical Discussion | 17 | 22-12-2003 19:19 |
| wheel hub kit and sprocket | archiver | 2001 | 7 | 23-06-2002 23:27 |
| DP of Window Motor Gear? | archiver | 2001 | 9 | 23-06-2002 23:24 |
| control system programming | archiver | 2000 | 17 | 23-06-2002 22:14 |
| shaft drive | Joseph F | Technical Discussion | 5 | 03-02-2002 17:51 |
