Go to Post Start building your robot as soon as possible, but not sooner. - Richard Wallace [more]
Unread 19-01-2004, 19:56
Matt Reiland's Avatar
'The' drive behind the drive
Re: How to turn down gear hubs?
Originally Posted by sanddrag
What is a trantorque? Is it something a well equpped machine shop would have? Google Image search didn't give me too much. Thanks.
Quick-Mount Keyless Bushings Since there are no keys, cap screws, or other components to slow you down, you can torque up one of these bushings in just seconds. Match bushing OD to bore of your sprocket, pulley, or gear.
Each bushing has inner and outer sleeves. As you tighten the collar nut, the inner sleeve contracts onto the shaft while the outer sleeve expands to hold your component. Bushings accommodate shafts that are slightly out of round. They're quick and easy to install and remove.
Stainless steel bushings are made of Type 303 stainless steel.
THis is from McMaster, Small Parts also sells them
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
simple engineering question Ben Mitchell Technical Discussion 2 07-11-2001 07:50
