Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
Unread 19-01-2004, 17:51
dradius's Avatar
dradius dradius is offline
breakdancaz
AKA: ryan
FRC #0624 (CRyptonite)
dradius will become famous soon enough
Send a message via AIM to dradius Send a message via MSN to dradius
Is the use of slip rings legal?
Use of slip ring in order to be able to spin wheel 360* without having to put a limit on the chain?
Unread 19-01-2004, 18:09
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: Is the use of slip rings legal?
Do you mean a slipring for electrical connections? I'm almost certain it would be illegal to run electricity through something thats not a wire.
I believe this was brought up last year (or the year before) and discussed in depth.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 19-01-2004, 18:11
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
To be perfectly honest I do not think that is what he is talking about. He is being a bit cryptic but apaerntly he is talking about something the drivetrain. Can you elaborate??
Unread 19-01-2004, 18:16
Slip Rings:
http://www.polysci.com/SlipRings/slipring.html
ARE these legal? Could they be considered part of a custom circuit? I have no idea.
If you mean something else and it's only mechanical it's probably legal, but better clarify to make sure. You want to spin a wheel (a drive wheel?) more then 360 degrees?
Greg
Unread 19-01-2004, 18:29
David66's Avatar
David66 David66 is offline
YA TOAST!
AKA: David Butzin
FRC #0066 (The Flyers)
David66 has a spectacular aura aboutDavid66 has a spectacular aura aboutDavid66 has a spectacular aura about
Send a message via AIM to David66 Send a message via Yahoo to David66
Am not positive about the entire slipring concept, however the bruches and the ring conducting electricity ARE legal...66 used them oon our mini-bot in '02 and i dont think that specific robot rule has been revised since then
Proud Alumni of Team 66
2005 Great Lakes Regional Champions with Team 67 (HOT) and Team 68 (Truck Town Thunder).
2005 West Michigan Regional Champions with team 107 (Holland Christian High School) and Team 93 (New Apple Corps)
2002 National Champions
Unread 19-01-2004, 18:50
Umm Errr...
It would be my interpretation of the rules, that there is nothign against slip rings, as long as they are rated for whatever it is you are using them for. Look at the parts flow chart.
1139 Alumni
Unread 19-01-2004, 19:12
I think it would be considered an electrical component, and therefore it would have to be available from one of the three catalog sources to be legal.
I dont know what you are up to that you want to use one- it boggles my mind just thinking about it.
Unread 19-01-2004, 20:08
Umm Errr...
None of what any of us say really means anything official, or is necessarily correct. If you are in doubt, i would recommend you ask FIRST.
1139 Alumni
Unread 26-01-2004, 15:55
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
In general, in the past, FIRST has held that any properly insulated electrical connector is fine as long as it is rated to a higher degree than the circuit breaker that is installed on the same circuit. Obviously, that does not mean that it would be legal this year but I would believe that it would not be illegal.
Matt
Unread 26-01-2004, 19:26
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
In the past, slip rings were specifically mentioned as things you could not use. However I saw no mention of them in the rules this year, and I'm not sure just when that little rule dropped from sight. So as long as it meets the other requirements for the electrical system I think it's OK.
Christopher H Husmann, PE
"Who is John Galt?"
Retaining rings and e-clips Gui Cavalcanti Technical Discussion 9 05-01-2004 14:42
Slip Ring KWachowski27 Kit & Additional Hardware 5 23-07-2003 00:23
gas shocks legal? ajlapp Rules/Strategy 3 01-02-2003 22:42
is this legal? archiver 2001 2 24-06-2002 00:58
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
