Go to Post Tell them your newfound passion for FIRST as a program, and let them know all you're doing is getting more involved to broaden your FIRST horizon - Dorienne [more]
Unread 16-01-2004, 14:02
Paul Marshall Paul Marshall is offline
Paul Marshall will become famous soon enough
Send a message via AIM to Paul Marshall
Servo Specs
Does anyone know who makes the servo's or where I can find specs for them. Or more specifically, how accurate/precise is are the servos?
-Paul
Unread 16-01-2004, 15:15
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Servo Specs
Specs for all the motors, including the Servos should be available on the FIRST docuent and updates page (Here) soon (should be by the COB on 1/16/04.).
-Michael Dessingue
Unread 19-01-2004, 20:32
Re: Servo Specs
So FIRST published the 2004 specs but I haven't seen any specs on the servo's, does anyone know where I can find them?
-Paul
Unread 21-01-2004, 13:32
Re: Servo Specs
HiTec HS-322HD spec is at http://www.hitecrcd.com/product_fs.htm
Unread 25-01-2004, 18:13
boostaddict boostaddict is offline
boostaddict is an unknown quantity at this point
Re: Servo Specs
does anybody know if the servo contained in the kit of parts has a futaba type connector or a Hitec\JR\Airt-Z connector? Also does anybody know off hand which distributor carries these for sale? thanks.
Unread 26-01-2004, 11:06
Re: Servo Specs
You can get the servos at servocity for $11 each.
They come with the proper connector for the FRC.
Unread 03-02-2004, 10:17
tml240's Avatar
tml240 tml240 is offline
bahh
tml240 is on a distinguished road
Re: Servo Specs
is this the servo model we use?
im not in electrical....
OHL 2004- ultimate NHL 2004 MOD
Unread 03-02-2004, 12:12
Re: Servo Specs
The HiTec model HS-311 or HS-322
2004 Motor specs - Part 1 Paul Copioli Motors 12 28-01-2004 17:40
servo problems lpramo55 Programming 5 20-01-2004 22:23
Q&A Discuss: Are specs available on the new motors/mounts? CD47-Bot Extra Discussion 3 15-01-2003 19:39
motor specs? Gary Dillard Motors 0 04-01-2003 17:54
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
