Go to Post We're 30 pounds over LOL. I probably shouldn't be lol'ing, but it is 11:52PM, I just got home from a 15 hour build session, and I find the word 'potato' funny. - ZakuAce [more]
Unread 18-01-2004, 23:56
Bob92 Bob92 is offline
Bob92 is on a distinguished road
Remote 10pt Ball Activation
Has anyone thought about knocking off the 10pt ball remotely. I think it would be a good idea if you wanted to catch the balls without releying on your alliance partner to activate the 10pt ball. I had thought about using some kinda of a scissor mechanism to deploy it at an angle twards the side barrier. It would then run along the side of the field till it hit the outer pole on the 10pt enclosure, pivot in to hit the ball and then you have 18 balls falling into your robot in what ever container you choose. It does not seem to complicated to me, EASILY less than 10 pounds. I just want to know what other people think of the idea
Unread 19-01-2004, 00:02
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Remote 10pt Ball Activation
I think its a decent idea, in theory, that might work (emphasis on might) However, you wont be able to store more than 5-6 balls on your robot, most likely, and even if you could store more, the balls fall everywhere, making it unlikely that you get many.
Cory
2001-2004: Team 100
2006-Present: Team 254
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Although I don't know of a specific rule, nor do I feel like searching for one, my past expieriences lead me to believe that FIRST wouldn't want you to react with the field borders in order to gain an advantage.
Could it be done? Definitly, but I don't know if it's legal.
Unread 19-01-2004, 00:11
I don't belive there is any rule againt any part of this strategy. Mostly because is automous mode teams do track parts of the field because they are a fixed position for dead reckoning. I also feel that there will be many robots that will be able to carry a significant amount of balls. I see many teams being able to expand to very large sizes and i belive catching the balls is a good strategy because there is less of an element of chance of when the balls will be at that given time. They will fall onto your bot if you can get there before another team knocks off the ball and if they don't you have a simple extention device to do it for you. This device could be quite similar to alot of extensions seen in 2k2.
Unread 19-01-2004, 00:48
robot180's Avatar
robot180 robot180 is offline
Webmaster, spamrobotics.com
AKA: Jon
FRC #0180 (S.P.A.M.)
robot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to allrobot180 is a name known to all
Send a message via AIM to robot180
This idea sounds perfectly legal, I think. I would just be careful and maybe prototype your idea before spending a long time building it, because it has a good chance of not working. Also, you don't have much experience with doing this, I think. It sounds like your robot would fall over due to the weight of the arm and the maximum size of the base of your robot. Also, it might be hard to find a way to fit this arm device, a hopper-type thing for holding the balls, an electrical system, a chasis, and four wheels or whatever in the envolope. Actually, it would be easy, but not one that holds enough balls that makes it worth it. I am probably wrong though.
Last year was my first year, so I missed ball collecting, only bin collecting. Bins were much easier to deal with, I think.
-Jon
Computer Science Major
Georgia Tech
Former Team Leader
FRC Team 180
Unread 19-01-2004, 00:50
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
you may want to check out rule <G05>
"ROBOT mechanisms used to remove the BONUS BALLS may extend beyond the playing field border as long as they are within the vertical pipe structure surrounding the BALL TEES. If a BONUS BALL is removed form the BALL TEE by a ROBOT that violates this rule, a 25 point penalty will be deducted from that alliance's final score.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 19-01-2004, 08:56
couple things-
there is an entanglement rule, so anything you "send out" from your bot cant be trailing wires across the floor (no little mouse-bots running around)
and I think any scissors like extention, if you could get it to reach the release ball, would have to be very light - and remember there will be a 130 pound bot barreling down on that postion from the other direction - there will be contention for postioning at the IR beacon - expect your extention to get mangled
robot footprint has to be 30 by 36 inches at the start, but you CAN have a robot with a 36 by 60 inch footprint that starts on its 30 by 36" side, and pushes itself over at the start of the match, or that unfolds a frame with a footprint as big as you want.
Unread 19-01-2004, 21:06
Couple things
I would have the extention on a pivot (to easily be pushed if another robot wanted to activate my balls for me).
I would also use an extention like that of robots in 2k2 who had extentions that were quite sturdy. This scissor mechanism could be deployed and retracted using ONE pneumatic cylinder. (Why do you need wires?)
Also why fall down and waste time?
Unread 19-01-2004, 21:27
Cory's Avatar
AKA: Cory McBride
A scissor link mechanism is notoriously unstable. As you start to extend a linakge that long, it likely would just flop over. I think your team is far better off putting your resources elsewhere.
Cory
2001-2004: Team 100
Unread 19-01-2004, 21:55
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
Another question that came up in my team's brainstorming session, though not by any means our strategy:
Could you hit the field border hard enough to knock the 10 pt ball(s) off their stand, but not damage the field?
I can see all these robots using elaborate tracking mechanisms and autonomous modes when another robot makes a beeline for the field border and accomplishes the same task.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
Unread 19-01-2004, 23:24
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I don't see anything prohibiting this in the rules, and Dean/Dave/Woody specificly pointed out following the border as one of the ways to find the bonus balls.
Wetzel
Unread 19-01-2004, 23:45
Andrew Rosselet Andrew Rosselet is offline
None #0188 (The force from the north)
Andrew Rosselet is on a distinguished road
Send a message via MSN to Andrew Rosselet
It would be hard to tell through just testing because the FIRST fields will definitely be built out of different materials... However, if you do succeed with such an idea, Those teams who spent many hours preparing their autonomous modes will probably get very annoyed...Good luck!
Unread 19-01-2004, 23:52
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
One of my suitemates just got this cool toy...
http://www.thinkgeek.com/cubegoodies/toys/60b6/
I'm not sure if it'd work for knocking the bonus ball off, but it'll knock your hat off at 15-20 feet...
Tom
Unread 20-01-2004, 07:38
Aignam's Avatar
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
Do you think FIRST'd allow it?
Tom
Oh, God bless ThinkGeek! ::giddy with all sorts of crazy, stupid ideas::
Unread 20-01-2004, 08:25
isnt the release ball sitting on a tee that stands on the floor? I dont think its connected to the field border (but I dont have my arena drawings in front of me.)
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
ball activation Martin Rules/Strategy 9 12-01-2004 17:16
Qotw [11-17-02]: Manchester or remote kickoff... Ken Leung Rumor Mill 19 09-01-2004 16:18
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
2004 Game BBFIRSTCHICK General Forum 112 19-04-2003 17:12
