Go to Post Is there anything more inspiring than inspiration? The answer is no; there is not. - Jared Russell [more]
Unread 19-01-2004, 21:57
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
Cool update on our robot
[IMG][IMG]http://us.f1f.yahoofs.com/bc/577ab905/bc/start.jpg?bfrzJDABOkoUM1jt
hey, we just spent the better of an hour getting this figured out, yeah baby, this is probably the one of the FEW peeks I will post of Team 1183's robot count yourself lucky
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 19-01-2004, 22:03
Team 1183
AKA: Justin
Team Role: Driver
Re: update on our robot
that didnt work... so
http://us.f1f.yahoofs.com/bc/577ab90...rzJDABOkoUM1jt
go there. and YES its wood, its just a template, yeesh
Unread 20-01-2004, 00:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Your link does not work. This thread would be most appropriate in the "Robot Showcase" forum.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 20-01-2004, 01:04
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
It's wood?! Yes!!1!
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
Unread 20-01-2004, 15:27
Team 1183
AKA: Justin
Team Role: Driver
alright, this is better, and for that post on treads, I think this design ( VERY basic, will be stepped up ) that even if you lose a tread, you still got drive wheels ( connected by chain? ) hm
Unread 20-01-2004, 17:38
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
If you are going to have the wheels connected by chain anyway, I would suspect that you don't really need the belt.
As long as your wheels were in the right places it would work the same and you wouldn't need to worry about the belt falling off or using tensioners. Also it would turn better.
Unread 20-01-2004, 19:36
Team 1183
AKA: Justin
Team Role: Driver
that top center wheel will actually be an adjustable tensioner, and treads offer better traction, with the wheels also powered it works for the better in gripping and moving, also the adjustable tensioner will be the drive motor, and if you ask how will that work, our little secret
Unread 20-01-2004, 22:37
Cory's Avatar
AKA: Cory McBride
If I had to guess, Id say that youre going to mount the motor using vertical slots, so that you can slide it up or down to tension the chain properly.
Cory
2001-2004: Team 100
Unread 22-01-2004, 06:25
Team 1183
AKA: Justin
Team Role: Driver
Cory
yeah, I think thats the plan.... anyone know of any suppliers of treads for robotics? instead of using cog belts?
Unread 22-01-2004, 09:48
Cory's Avatar
AKA: Cory McBride
www.brecoflex.com<------Takes forever for them to arrive
http://www.fnsheppard.com/ <----- Team 45 used this supplier and I think they liked them more than Brecoflex.
Good luck
Cory
2001-2004: Team 100
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
