#10
Re: How to turn down gear hubs?
If I were going to take the hub off, I'd clamp it in a vise with aluminum inserts ("soft" jaws) so as to not damage the teeth. I'd think this would only work if you have an even number of teeth, though; I think it'd get shaky with an odd number (clamping down on 3 instead of 4 teeth).
If I was going to take the diameter of the hub down, I'd do one of two things. If I wanted to do it absolutely right, I'd do what someone else suggested and mount a keyed shaft in the lathe and mount the sprocket/gear. If I wanted it done faster and cleaner I'd mount the gear to a rotary table and take off the hub with a milling machine, or mount it to a CNC's vise and say "give me a small circle here" ![]() |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Drivetrain help | thedillybar | Technical Discussion | 9 | 08-01-2002 21:54 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
| simple engineering question | Ben Mitchell | Technical Discussion | 2 | 07-11-2001 07:50 |
