Go to Post Liberal arts majors learning more STEM concepts along with STEM majors learning more 'liberal arts' is a good idea. - ebarker [more]
Unread 19-01-2004, 14:30
Darksun Darksun is offline
Darksun is an unknown quantity at this point
Moving Mobile Goals
Hey everyone. I was wondering if there is a way to actually grab onto the goal. Originally it appeared that the only way would be to try to grab the edge of goal, but looking at the animation recently released by FIRST, there seems to be a lip that a robot could grab onto easily with a pneumatic pump. I've looked at the drawings, and can't seem to find it. Can anyone tell me if this actually exists, and its thickness and depth if it does? Thank you very much.
Unread 19-01-2004, 20:02
Eric Thompson's Avatar
Eric Thompson Eric Thompson is offline
Go patriots!
#1415 (Astroguard)
Eric Thompson is an unknown quantity at this point
Wink Re: Moving Mobile Goals
I believe that there is an extruded edge around the top. This way you will be able to either grip or hook the edge from the top only. My team is perparing to hook the top in order to drag it to our destination.
Unread 19-01-2004, 22:14
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
From what I saw at kickoff both in the chiars during the uplink and the brainstorming sessions FIRST ha dmade it clear that you may only grab the edge of the goal. You may not grab the PVC pipes / you may not raise the goal.
According the FIELD diagrams here is what I dug up
2004 FIRST Elements Moveable Goal
Item # 6 Qty 6 Description 1x1x1/8" Steel Angle Length 24" Remarks None
Steel Edging is cut to 2' pieces
Rule 24: Robots can only grab a mobile goal by the top metal edge of the goal platform perimeter. No part of a robot can extend under the base of the mobile goals. Robots may never grab or attach to the poles. If a robot grabs any other part of the mobile goals or extends under the base of the mobile goal, the referee will give one warning. If they referee decides that the team is dis reguarding that warning, the teams robot will be disabled and the team will be disqualified
Mike
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 22-01-2004, 08:13
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
Per an answer on FIRST Q&A, there is a lip on the goals that is about 1 inch high and 1/2 inch thick. It is made up of the diamond plate on the front backed up by a 1 inch angle.
Unread 22-01-2004, 08:49
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
I've already designed a mechanism to use the rotational actuator to grab a goal by the lip, but I was wondering what anybody thought about the legality of hugging the goal about the dimond plate... I'm not grabbing pvc, not lifting it up, just rapping arms around it to get a better grip.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 22-01-2004, 09:40
Bob Steele's Avatar
AKA: Bob Steele
I just wanted to add to your message. You MAY raise the goal as long as you do it by contact with the metal edge. Just not from anywhere else.
thanks
Bob
QUOTE=Mike522]From what I saw at kickoff both in the chiars during the uplink and the brainstorming sessions FIRST ha dmade it clear that you may only grab the edge of the goal. You may not grab the PVC pipes / you may not raise the goal.
Mike[/quote]
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This is not where you want to ask that question. You're going to get 20 replies from people making wild guesses that count for nothing out on the field. I would ask this on the FIRST Q&A forums.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 22-01-2004, 09:47
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
thanks
Bob
I'm still pretty sure you're not allow to raise or tip the goal even if it is by contact with only the diamond plating. You can attach to the edge on the diamond plating, you can push on the diamond plating, you can wrap around the diamond plating, you CAN'T lift the goal, you CAN'T tip the goal on one end, and you CAN'T contact the PVC intentionally. That was my interpretation, If I'm wrong tell me.
Unread 22-01-2004, 09:52
Cory's Avatar
AKA: Cory McBride
<G24> ROBOTS can only grab a Mobile Goal by the top metal edge of the goal platform perimeter. No part of a
ROBOT can extend under the base of the Mobile Goals. ROBOTS may never grab or attach to the poles.
If a ROBOT grabs any other part of the Mobile Goal or extends under the base of the Mobile Goal, the
referee will give one warning. If the referee decides that the team is disregarding that warning, the team’s
ROBOT will be disabled and the team will be disqualified.
<G25> If ROBOTS intentionally tip over any Mobile Goal or damage the poles of a Mobile or Stationary Goal,
that team’s ROBOT will be disabled and the team may be disqualified.
Like I said, Q&A
2001-2004: Team 100
Unread 26-01-2004, 21:16
c-squared_2006 c-squared_2006 is offline
Student Leader / Scout
None #1015 (Pi Hi Samurai)
c-squared_2006 will become famous soon enough
Talking Re: Moving Mobile Goals
Well, I think that we can safely say that 'hugging' goal around the diamond plate area is not allowed.
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Fighting the goals... archiver 2001 3 24-06-2002 00:51
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
