Go to Post Get your team together. Get your priorities straight. Get busy having fun. See you on the field. - EricH [more]
Unread 20-01-2004, 07:21
Re: Removing Bosch Drill Pins - Cause of Failure?
Originally Posted by Kevin Ray
We had treads last year and when we wanted to dead-recon turn by stopping one tread and continuing forward with the other, the bot had so little resistance on the stopped side (no backwalk pins) that it continued to roll forward and not turn at all.
Kevin,
I think what you were up against is the extreme friction produced by tank treads. Even with the speed controllers set to brake, there is not enough force to hold back the non-moving side. You have to visualize the transfer of forces as the robot tries to turn and that the treads are trying to slide sideways as well. Tank treads are OK for certain games but they are bad if you want manuerverability and low current demand. If you look at the Innovation First site I think they still have a paper showing the currents generated by different drive systems. You can't stop a tank but you can't turn it on carpet either.
Bosch Drill Motor rmmlg Inventor 7 17-12-2003 14:33
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
Replacement Bosch drill motor assembly james700 Motors 3 31-01-2003 21:08
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Bosch Drill Motor CAD Files Madison Inventor 10 09-12-2001 00:14
