Go to Post It's not about taking risks, but more about identifying them (which is the hardest part) and reducing them. - Deke [more]
Unread 20-01-2004, 11:30
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Swerve^2 Prototype
Unread 20-01-2004, 11:31
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Re: pic: Swerve^2 Prototype
Are you using potentiometers or digital encoders to track the orientation of your wheels?
Also, can I get a close-up shot of your drill's gearbox? It looks neat.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 20-01-2004, 15:29
Stormhammer's Avatar
Stormhammer Stormhammer is offline
Team 1183
AKA: Justin
#1183 (Eagle Executioner's)
Team Role: Driver
Stormhammer can only hope to improve
Send a message via AIM to Stormhammer Send a message via Yahoo to Stormhammer
k, now THAT is interesting... though... hm
1-2-3 EXE... prepare to be executed - Eagle Executioners ( no more Eagle Engineers ) #1183
Its either a Mopar or no car
Dude, WHY ARE YOU SO SLOW?!?!
Unread 20-01-2004, 16:10
REVving up for a new season
FRC #2848 (All-sparks)
very nice system....have you had any problems with drawing too much current or stalling the drill motor since you are only using 1 to power all 4 wheels?
Unread 20-01-2004, 22:00
WakeZero WakeZero is offline
FIRST-a-holic Strategist
#1011 (CRUSH)
WakeZero will become famous soon enough
Send a message via AIM to WakeZero Send a message via Yahoo to WakeZero
We use two pots on both steering chains to determine position, so four total. As for the one drill motor issues, we have noticed that problem to a small extent... but they will go away once we install the second drill
2004 Arizona Regional -- Semifinalist
2003 NAT Galileo Division -- Highest Seeded Rookie (20th)
2003 NAT Galileo Division -- 100% Autonomous Completion (7 for 7)
2003 Arizona Regional -- Rookie All-Star Award
2003 Arizona Regional -- Quarterfinalist
Alumni on Team 64, The Gila Monsters
College Mentor/Founder of Team 1011, CRUSH
Unread 21-01-2004, 00:00
#1011 (CRUSH)
We lovingly refer to this little contraption as the X-Box, since it's chains form an X that go out to drive each wheel. What it allows is for two drill motors to be mounted horizontally on the robot to drive the wheels. It also has a nice feature in that it makes the drill motors spin in the same direction (Clockwise and Clockwise, or CCW and CCW)
We may be taking out the four shafts around the middle one and just putting four or two sprockets on the top of the middle shaft... we would only do this if we thought it was too inefficient, or we were hurting for weight
Unread 21-01-2004, 00:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
It's clear that it can translate along the ground -- but how does it turn? With two motors powering a single gearbox that drives all four wheels, is differential steering possible?
--Madison--
...down at the Ozdust!
Unread 21-01-2004, 00:29
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
looks like they also are using crab drive with different motors powering the turning
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 21-01-2004, 00:38
#1011 (CRUSH)
Here is what we use to turn ONE set of wheels. We have one of these on the back two wheels, and one on the front. You can't see them in the picture because they are mounted upward, and hidden by the frame
I explained it in the picture description, but that doesn't show up in the discussion. So here it is again
Yes, it does drive on it's own power up the small steps. Right now we have one drill motor driving all four motors, this will eventually be two. To steer we use two globe motors, one for the front wheels and one for the back. This allows us to do two things:
A) Tank-turn by turning the front wheels 180 degrees from the back wheels. This allows us to change the robots orientation easily.
and
B) Change to a car drive mode where only the front wheels turn.
To drive the swerve, right now we have one joystick. In programming we convert the x and y coordinates to polar by using lookup tables. This gives us the angle we want the wheels to face, and then the magnitude for how fast we want to drive.
Unread 21-01-2004, 01:08
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
From what I can tell, it looks like there is no support on the other side of the globe motor shaft. It may just be the picture you showed, but in that configuration there is a significant side load that (typically) results in the globe motor releasing its magic smoke
If I am incorrect, sorry about that... Just thought I would note that... its an easy fix.
Otherwise it is VERY original! Looks good!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 21-01-2004, 01:43
WizardOfAz's Avatar
WizardOfAz WizardOfAz is offline
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
WizardOfAz will become famous soon enough
Send a message via AIM to WizardOfAz
Well, you're right about that. I've worried about it some, but since steering is such light duty cycle, I don't think we'll have a problem. Also, the side load is very close to the motor - it would be much worse with a longer shaft. I'd guess in a typical game we'll turn the wheels an aggregate of a few revolutions, maybe a few tens at the upper bound. In our setup, the globe motors rotate 2.8x as fast as you steer the wheels, so maybe we'll get on the order of 100 total turns of rotation in a game. I'm thinking the motor won't suffer much with that much use. Does this disagree with your intutition or experience?
Bill
Unread 21-01-2004, 04:56
Engineering Mentor
FRC #0254
Your assumption would be correct for almost all motors in the kit except the globe motor (in my honest opinion).
For some reason (maybe someone knows specifically) the globe motor is VERY sensitive to side loads. In past years when my team used these motors, if the shaft was not supported on both ends we would ruin the motor, even if it was used rarely.
If it is possible (it looks failry easy) you might want to try and put a bearing supporting the shaft on the other end... even though you might not really need it... it seems like it serves an important enough function to deem the extra work beneficial... even if it only gives you peace of mind.
Hope that helps
-Travis Covington
Unread 21-01-2004, 10:19
#1011 (CRUSH)
Thanks Travis, we will surely be looking into this now
Unread 21-01-2004, 12:02
President, VEX Robotics, Inc.
I am going to have to back up Travis on this one. We used the globe motors for swerve steering in 2002 and we hade to add a bearing to support the load. We ruined 3 globe motors on our prototype unitl we figured it out. Once we added the bearing, we did not fail any globe motors.
-Paul
Unread 21-01-2004, 12:44
WizardOfAz's Avatar
Lead Mentor
AKA: Bill Bennett
FRC #1011 (CRUSH)
-Paul
OK, I hear the growing concensus. Our original design had a top plate and a bearing. Just "simplified" it to a single plate to the the prototype going quick, and it worked pretty well, so I was hoping to leave it that way. The prototype in the photo will be getting some road time in the next few days, so we'll see how that goes. What are the first symptoms of impending failure? Noise? Smoke? Just locks up?
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
