Go to Post sometimes you just have to escape the wheel. - Tytus Gerrish [more]
View Poll Results: Were teams successful with a tank tread drive?
It worked all the time. 18 43.90%
It was a nightmare. 6 14.63%
It sometimes worked but always required constant maintenance. 17 41.46%
Voters: 41. You may not vote on this poll
Unread 19-01-2004, 21:22
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Success with Tank Treads
Poll: Were tank treads easy, hard, or ok to deal with for teams who have tried in the past? Basically, did they function well all the time, some of the time, or were they a nightmare?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 19-01-2004, 21:54
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Re: Success with Tank Treads
It seems like me that it would be too difficult to turn in a game like this where maneuvaribility is very important and power not so much.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 19-01-2004, 21:56
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Dont be so quick to assume that I think we'll see some pretty powerful bots.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-01-2004, 22:02
well lets see *opens super secret robot design* i think some teams might be thinking differently this year, and go with power *closes super secret robot design, then gets a cheeseburger*
Unread 19-01-2004, 23:11
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Treads are not trivial to design, build, and maintain. While they might not be to the level of "nightmare", they sure cause some sleepless nights.
The advantage of treads are:
1. Increases your ability to climb things
2. Provides a bit more traction, depending on the playing surface
The disadvantages of treads are:
1. Requires more weight allotment compared to wheels
2. Reduces your driving power due to a less efficient drivetrain (the belts must be pulled very tight in order to stay on, causing high side loads on your pulleys and bearings)
3. The cost is very high (more expensive bearings, numerous pulleys, costly treads, more spare parts).
4. They take longer to design and build. Our team has never been able to get a tread system driving before week 4. Prepare to have very little drive practice.
5. Losing a tread = losing a match
If you are putting treads on your robot, keep your belt tight, keep your pulleys aligned, and be sure to put a "bow" on the bottom surface of your tread (middle pullies should be lower than outer pullies).
That's just my opinion. Others might have had an easier time with these treads, but after putting them on team 45's robot for 4 out of the last 5 years, this is how I see things.
Andy B.
Unread 20-01-2004, 09:11
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
In 2000 237's bot originally had tank treads (I know, can you believe it? ), which basically lasted through our practice rounds at UTC. I couldn't go that day, but the people who came back looked crestfallen...the thing was slow as molasses and was too troublesome. After our practice rounds, the pit crew made the decision to switch to wheels...and it was the best decision we could have made. We ended up seeding in the top 8 and walking away with the win.
I'm not saying that treads are always a bad decision....they do have their good points (Baker already listed them above)...and I trust that they went through all those pros and cons before they decided to originally use them.
In the end, it's just a personal decision your team has to make. Use these pros & cons, compare them with what your team wants to be strong at and the answer will be clear
Unread 20-01-2004, 09:25
adunakin adunakin is offline
adunakin is an unknown quantity at this point
618 went with treads last year and did well. While I do agree with the simplicity arguement against treads, who said life had to be simple!
Unread 20-01-2004, 12:04
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
http://www.valleytech.k12.ma.us/robo...2%20Monday.jpg
We have been doing tracks for 10 years now.
The most important thing is you power train. if you get your power just right the tracks work great.
We found out how much power a track can take. What we did was speed up the track which lowers the power. This way the robots is fast and still have great pushing and pulling power. with out ripping the tracks
Tracks are very costly but done right is very easy to drive under auto mode and very easy for the driver to control.
Last thing you need to keep your center of gravity as low as you can. this also helps out the tracks
Unread 20-01-2004, 12:13
Generator of Entropy
FRC #2973 (The Mad Rockers)
Andy B.
I agree with most of Andy's post - SPAM has had a tread drive system since our second year and it's evolved every year. It's hard to break down the design / manufacturing time in the drivetrain - our gearboxes are always very complex and switching them to a wheeled system wouldn't have saved much time. We were never power limited, always traction limited. Most people would agree that in 2002 we could push any other robot with impunity (except Mike Norton - still waiting for that video where you claimed to dominate us); last year we made some changes that apparently had major impacts because we lost / locked treads several times when being pushed from the side, including important matches such as the Division Finals.
I think we actually did win a qualifying match in 2002 with a broken belt, but we were already in pretty good position when it snapped.
The bow in the bottom (middle wheel lower) is a gotta have - we call that the "boogie wheel" because it allows you to turn on a dime without dragging / slipping the belts. Ours is spring loaded.
A couple other down points to consider:
Brecoflex belts (by far the best we've used) are very expensive and have a long lead time (probably why we were never driving until week 5)
Maneuvering takes longer and is harder to do in short spaces because of the added side drag.
Metal-in-Motion made the Finals with belts last year, so as far as success is concerned this is only one aspect that you need to make work for you if you choose.
Unread 20-01-2004, 13:12
FRC #0061
Rookie Year: 1995
I found that video. What was happening was your robot would stall or stop running and we would pull you. then we would stall and you pulled us then we pull and you ended up letting go and went for another goal. But what happen we turn sideways and you couldn't push us out of your way so time ended with you not back in your zone.
I would say both robots were quite equal in power. but I think you had 2 speeds becuase you were quick off the mark.
I hope to see you this year in UCF.
Back to the tracks the best thing about them is if you do turn sideways not many if any could push you.
Unread 20-01-2004, 20:41
FRC #0061
Rookie Year: 1995
Take a look at the new tracks for this year. a nice new look with a strong 1" shaft. Last year we spun 4 of our drive shafts, to much power so we are running with 1" this year.
http://www.valleytech.k12.ma.us/robo...photos2004.htm
Unread 20-01-2004, 21:28
Cory's Avatar
AKA: Cory McBride
Very spiffy looking pulleys you have there. Looks like we'll be seeing another powerful bot from 61 this year
Cory
2001-2004: Team 100
Unread 21-01-2004, 11:53
Looks sweet again Mike - and to the point of this thread, you can see how much design and machining time goes into making a tread system work. The sprocket you see there comes solid stock, just the teeth and the bore cut; all the weight reduction getting to the cool looking spokes and the attachment holes plus the drive shaft takes design, NC programming and machining time.
Unread 21-01-2004, 14:01
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
BAck in 95 when Nashua was a well known team, we used tracks for our bot...they were so well designed and made that they did not need to be replaced until after nationals! adn they were on it since around week 3! now the bot did horrible, but the drive was a tank!
Our team this year(134) has taken advantage of the awesome breckoflex tracks, they are totally amazing, a self tracking feature? who woulda thunken! and hey CD...Pembroke this year will be a force to be reckon with.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 22-01-2004, 20:08
FRC #0061
Rookie Year: 1995
http://www.valleytech.k12.ma.us/robo.../2004VIEW1.jpg
http://www.valleytech.k12.ma.us/robo.../2004VIEW2.jpg
http://www.valleytech.k12.ma.us/robo.../2004VIEW3.jpg
http://www.valleytech.k12.ma.us/robo.../2004VIEW4.jpg
http://www.valleytech.k12.ma.us/robo.../2004VIEW5.jpg
Here are some pictures in cad to give you a better look at a simple track design
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
pneumatics tank archiver 2000 2 23-06-2002 22:43
What problems have you encountered using treads? M.I. Technical Discussion 8 15-01-2002 22:13
