Go to Post Part of the magic of FIRST is the interaction between different teams- and that becomes clear as day as the clock starts ticking. - mhayon [more]
Unread 19-01-2004, 21:42
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Bimba Pneumatics CAD site
I found this useful, so you all may think the same.
There is a nice site at Bimba that will let you download CAD files for their rotary actuator and cylinders.
Here is the link. The cylinders are under "non-repairable stainless steel cylinders" and the rotary actuator is under "pneu-turn rotary actuator".
Enjoy!
Andy B.
Unread 20-01-2004, 12:31
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Bimba Pneumatics CAD site
Were you able to download anything? I put in a part number (178-DP for the 1-1/2 inch bore 8 inch stroke cylinder) and it doesn't recognize it for native ProE (which would be great for me). I tried a couple other part numbers and no luck - they do work on other parts of the website such as searching for cost so it looks like the part numbers are good.
Unread 20-01-2004, 13:21
I used it for the rotary actuator (PT-017090-M), and it worked really well. I downloaded a stp file, but it seemed like they had every type of file imaginable.
Andy B.
Unread 20-01-2004, 15:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I was using Bimba's CAD models just a few days ago. Very nice
Gary: You could always just download the IGES format.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 21-01-2004, 11:58
Except I lose the parametrics when I go to IGES. If I could import it in ProE I could setup a parameter and the stroke position would change based on the position of the end points (or vice versa). I have a cylinder in there now with that feature, but it would be nice to have the other stuff located correctly such as ports
I'll check the other formats -step and IGES usually come in pretty clean but not parametric.
What do you use to make your team site!? activemx Website Design/Showcase 68 15-01-2003 18:32
NEW site dedicated to the UTC New England Regional! archiver 2001 2 24-06-2002 01:13
CAD Drawings? archiver 1999 17 23-06-2002 22:35
Excellent Inventor CAD site..... Clark Gilbert Inventor 2 04-03-2002 00:50
CAD file site update announcement ..... Ed Sparks General Forum 0 13-01-2002 20:55
