Go to Post Many students I have met will insist that nothing is better than FIRST robotics. And most people would agree that a ham sandwich is better than nothing. So does it logically follow that a ham sandwich is better than FIRST robotics? - tsaksa [more]
Unread 18-01-2004, 13:06
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
I-sprocket?
Hi. Yesterday I was working on the inventor for our drive train, but we ran into a problem. One of the parts on the first cad library (i-sprocket.ipt) would not place right on the assembly. After I entered the parameters and tried to place it, Inventor gave me a long list of errors. Has anyone else had problems with this? Does anybody know how to fix it?
Thanks,
Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 18-01-2004, 13:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: I-sprocket?
What Inventor are you using? It's been okay for me in 5.
Unread 18-01-2004, 13:23
AKA: DFB
FRC #0125 (NUTRONS)
Re: I-sprocket?
I am using inventor 6.
Unread 19-01-2004, 11:09
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: I-sprocket?
Thanks,
Daniel
Daniel,
I-factory parts will "blow-up" if you happen to choose parameters that don't make sense like a bore diameter thats larger than the OD of the sprocket. What parameters are you using ?
Ed Sparks
MECH TECH FRC-3959
Unread 19-01-2004, 13:05
AKA: DFB
FRC #0125 (NUTRONS)
Re: I-sprocket?
Paramaters:
Chain pitch: 3/8 in
Number of teeth: 45ul
Bore diameter: 5/8 in
Hub diamater: 2.291 in
Key Width: 1/8 in
Hub: Compute
Keyway: Compute
Thanks,
Daniel
Unread 19-01-2004, 19:01
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
Re: I-sprocket?
It doesn't work for me in 7 either.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 20-01-2004, 14:17
Exclamation I-Sprocket Fixed .......
I found the issue with I-Sprocket .......
It's posted in the First Cad Library. I've tested it under Inventor 5 & 6. If a few of you could please test this part with Inventor 7 and get back with me I would appreciate it.
Big thanks to Daniel Wong for his assistance in tracking down the problem.
PS. I've also posted the Grounding Terminal
Ed Sparks
MECH TECH FRC-3959
Unread 21-01-2004, 19:26
AKA: DFB
FRC #0125 (NUTRONS)
Re: I-sprocket?
Thanks Ed. It's working for me now.
-Daniel
If set screws suck . . . Madison Technical Discussion 17 22-12-2003 19:19
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
DP of Window Motor Gear? archiver 2001 9 23-06-2002 23:24
control system programming archiver 2000 17 23-06-2002 22:14
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
