Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 20-01-2004, 17:09
hedgehogger hedgehogger is offline
hedgehogger can only hope to improve
Im Having Problems With Mplab!!!!
WHat driver do you use for a USB serial converter for windows XP im having trouble locating it, how can i find it!! Or even better where???
-hedgehogger
Unread 20-01-2004, 17:32
Bharat Nain's Avatar
Re: Im Having Problems With Mplab!!!!
Everything is in the CD provided. It contains the whole MPLAB+USB Driver+IFI Loader. Alternately, try searching at www.innovationfirst.com . I remember seeing a MPLAB download there.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 20-01-2004, 17:43
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
What I always use to download drivers is Driverguide.com. Login (User=driver, password=all), and start searching. I can't give you an exact link because I don't know your exact hardware.
Hope that helps!
Im am having trouble with the MPLAB hedgehogger Programming 7 19-01-2004 17:37
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
