Go to Post Ah, the FIRST Community, aka The Land of Little Patience :) - Jessica Boucher [more]
Unread 20-01-2004, 13:55
Tallman Tallman is offline
Tallman is on a distinguished road
IR Tracking & Navigation
Attached is a copy of some notes I put together for the IR Tracking stuff. I decided to share it everyone. Hope you like it.
Disclaimer: This was only to serve as a guide, please check the code for exact values and operations.
Mike
Unread 20-01-2004, 16:39
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Re: IR Tracking & Navigation
Mike
This is what FIRST should have included. Unless something got lost from our kit (quite likely), I had no clue about even the basic setup of the system. This is a broad overview of the default code and the theory of the algorithm. I always believe that the easiest way to learn something is to get a general sense of what it does and then dive into specifics. By not releasing any detailed docs, FIRST just made a lot of us lost in the specifics of the code.
There are also some pictures of a sample setup on http://www.kevin.org/frc somewhere, but they don't appear to be linked from that thread. A simple search in the programming or electrical forums will bring these pics up.
My suggestion: Add pictures of your setup to the doc (or graciously and professionally rip Kevin Watson's pictures) and submit it as a whitepaper.
+rep
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 20-01-2004, 17:02
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Feel free to graciously and professionally rip anything from my website for inclusion in your documentation. BTW, the pictures are located here: http://kevin.org/frc/tracker everything else is here: http://kevin.org/frc
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2004, 17:26
edflyerssn007's Avatar
edflyerssn007 edflyerssn007 is offline
AKA: Voice of God
#0329 (The P-Town Pirates)
edflyerssn007 is an unknown quantity at this point
Send a message via AIM to edflyerssn007
I am working on building an IR beacon, which pins are which, i found a diagram of the outside, what the packaging type was supposed to be from the docs i downloaded off of kevin's website, but there is a notch that doesn't exist on the one we got from the kit. So which pin is which?
Example Beacon Tracking Code Posted Kevin Watson Programming 0 17-01-2004 02:25
Default IR navigation code Atheist Programming 0 16-01-2004 15:05
An Example IR Beacon Tracking Assembly... Kevin Watson Electrical 0 14-01-2004 12:30
Electrical componenets for autonomous navigation maclaren Electrical 10 18-12-2003 02:28
page navigation Brandon Martus Announcements 2 06-12-2001 21:12
