Go to Post This exercise in thanking the hand that teaches you brought to you by the Unsung FIRST Heroes Award. Have you thanked your mentor lately? - Amanda Morrison [more]
Unread 14-01-2004, 23:13
lpramo55's Avatar
lpramo55 lpramo55 is offline
#0353 (POBOTS)
lpramo55 is an unknown quantity at this point
Send a message via AIM to lpramo55 Send a message via MSN to lpramo55 Send a message via Yahoo to lpramo55
Exclamation servo problems
been searching the threads for hours...if anyone has been having problems with their servos. I have two servos switching the transmition of "spare parts" (our copy of our competition bot) connected to the same pwm03 on our RC. no matter what our code outputs from that pwm out the servos do nothing. we tested the servos, y-cable, and outputs. what's left?! am i missing something the only thing we can come up with is that old servos dont work w/ new controller....but that makes no sense...a servo is a servo!
HELP!
Thanks,
Team 353
Unread 15-01-2004, 00:01
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: servo problems
Do you have the backup battery hooked up? The power for the servos comes solely from backup input.
Unread 15-01-2004, 22:07
Servo888 Servo888 is offline
#0062 (Grobot)
Servo888 is an unknown quantity at this point
Re: servo problems
have you tried just a 7.2volt input directly to the servo? If it moves it's still good; if not it could be fried. Now if all your servos don't work than the only thing I can think of is that the controler is not providing enough power for the servo.
cheers
-servo
Unread 15-01-2004, 23:29
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Re: servo problems
On the servos the black and red wires carry power to the servos, and the white/yellow wire (I am not sure what the colour is) is a signal wire which tells the servo what to do. Simply applying power to the servo won't tell you anything because it won't be receiving any signal, so it won't have any instructions to follow, as a result it will just sit there looking pretty. Make sure the servo is connected to a PWM output, and not one of the relay outputs, and make sure that particular channel is active, properly programed, and assigned to a control.
If you built an EDU/BETA bot this year, plug the servo into the radio system you purchased, power it up, and it should work (make sure it is plugged in properly). This servo was originally designed for use with radio contol systems like the ones used to control the BETA/EDU Robots. If it STILL doesn't work, it's probably pooched.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 20-01-2004, 22:13
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: servo problems
regarding servos, how many servos are we allowed to use this year. This is because the manual doesnt answer the question if the servo is a motor or not?
Unread 20-01-2004, 22:23
AKA: Chris
Re: servo problems
From the Q&A :
Section: 5.3
Status: Answered
Date Answered: 1/20/2004
Q: Are servos treated as electronics (in which case we can have an unlimited number of them) or are they treated as motors (in which case we are limited to 2)?
A: Electronic
quatro OI for edubot problems Benedictine1 Robotics Education and Curriculum 2 22-12-2003 12:47
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
