Go to Post Some of them look like phone numbers... LETS START CALLING THEM ALL! - akoscielski3 [more]
Unread 20-01-2004, 22:33
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Rookie team drive tream idea
Originally Posted by Eric Bareiss
Wow, you guys are all over the place with your answers.
I would say Yes to all of the original questions except the gearbox question. I would reccomend that a newer team with little machining help or expertise not try to build a gearbox from scratch. If you are deadset on using the Chips, try to keep it as simple as possible.
As for traction I can't imagine having too much traction with these new wheels. You should be able to turn just fine and go up the step without too much trouble.
It's very tempting to go with your suggestion; it was the only one that gave me a complete answer .
That still leaves me with a question, if we shouldn't build the gearbox, where should we get one?
Unread 20-01-2004, 23:23
Fold em oval!
If there are any other Rookies out there following this, here is a very pertinent paper about being able to turn with tank style turning:
http://www.chiefdelphi.com/forums/pa...le&paperid=222
Based on this paper, I think maybe some friction tests (in both directions) of these 12 inch wheels are in order
Team 1257
Unread 21-01-2004, 03:36
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
As for using a gearbox, my suggestion would be to use the one that comes in the kit. I haven't seen the one from this year, but I know the one from last year could be retrofitted for use with chips.
I'm not saying that making a gearbox is totally out of the question. You can surely do it with a drill press if you had to. I would get a good idea of what you think you are capable of and work from there.
My suggestion to you is to find a veteran team who would be willing sit down with you for a day and help you work out some plans for a gear box, maybe even help you machine it. It looks like team 25 is only about 15 miles away from you, I'm sure they would be willing to help.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Disqualifications archiver 1999 13 23-06-2002 21:53
TEAM 121 and a rookie team on CBS SAT MORNING! Joe Menassa General Forum 7 21-03-2002 00:47
