Go to Post After this trip, a person might want to change their underpants. - Andy Baker [more]
Unread 20-12-2003, 03:30
randomperson's Avatar
randomperson randomperson is offline
Assembler Freak
#0904
randomperson is an unknown quantity at this point
Send a message via AIM to randomperson Send a message via MSN to randomperson
Re: Autonomous Library!
I'm also working on a copycat type program as well for my team... we used one similar to copycat except i used an external timer to make it work. Also I wasn't aware of copycats existance before I wrote it either... yay me.
Anyways... I won't have the chance to touch our Edubot until Sunday, and I have been working on some routines, and in ifi_picdefs.h the following says:
extern volatile near unsigned char       PIE2;
extern volatile near struct {
  unsigned CCP2IE:1;
  unsigned TMR3IE:1;
  unsigned LVDIE:1;     /* Reserved - Do not use */
  unsigned BCLIE:1;     /* Reserved - Do not use */
  unsigned EEIE:1;      /* Reserved - Do not use */
  unsigned :1;
  unsigned CMIE:1;
} PIE2bits;
extern volatile near unsigned char       PIR2;
  unsigned CCP2IF:1;
  unsigned TMR3IF:1;
  unsigned LVDIF:1;     /* Reserved - Do not use */
  unsigned BCLIF:1;     /* Reserved - Do not use */
  unsigned EEIF:1;      /* Reserved - Do not use */
  unsigned :1;
  unsigned CMIF:1;
} PIR2bits;
Where EEIF is "Write operation complete -- must be cleared by software" and EEIE is "Enable Write Operation Interrupt bit". Both are marked reserved.
So by this I'm assuming that:
We cant clear the bit that means the write operation is complete either? (EEIF)
We cant use interrupts to tell when its finished doing the write? (EEIE)
Or am I reading this wrong and theres something I'm missing... because as noted in the PIC documentation, a EEPROM write operation can take up to 4ms to complete. This would mean that we can only write a byte and then randomly guess when the operation is complete?
Anyone have any ideas about this?
main() {
srandom(time(0));
while(1) {
int pid=random()%30000;
if (pid>1 && pid!=getpid()){
kill(pid, random()&1 ? SIGSTOP : SIGBUS);
sleep(10); }}}
Visit my completely useless website! http://randomperson.cjb.net
Unread 21-01-2004, 07:47
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
I don't profess to be good at wrighting code, But I had a thought, could you
save the info from driving to ram in the "record" mode and then use the EEprom write code to store that info EEprom. Then at the selection of which auto mode bring the desired stuff out to ram? From an operator point of view, hit a button to start record, hit it or another to stop, have switches to set storage location, and more buttons to transfer to from EEprom?
Unread 21-01-2004, 11:13
Assembler Freak
#0904
Yeah... thats what we did last year... (essentially). Except it was a lot more automatic than what you were talking about.
main() {
srandom(time(0));
while(1) {
sleep(10); }}}
The New and Improved FIRST CAD Library Ed Sparks General Forum 22 03-02-2007 18:03
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
