Go to Post FIRST is difficult and it is challenging, but you aren’t necessarily required to go off and build an 8 motor drivetrain and 4 motor / 8 pneumatic piston arm mechanism for the heck of it when a 2 motor non-shifting drivetrain and 2 motor arm does just as good a job. - Bill Gold [more]
Unread 21-01-2004, 16:09
Jesse Jesse is offline
Jesse is on a distinguished road
Requestion Bosch Motor iformation please
Can you tell us if the Bosch Motors are connected directly to the wheel without the use of a transmission or anything else? Also we would like to know if the Bosch Motors are equipped with variable speeds or is it just all or nothing. Thank you very much.
Unread 21-01-2004, 16:33
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Re: Requestion Bosch Motor iformation please
Jesse, It sounds to me that your team needs an engineering mentor who at least has some basic knowledge of drive trains. I will give you some quick advice, but your team needs to thoroughly understand this so you will be prepared to deal with it at competitions.
The Bosch drill motors, by themselves run at extremely high speed and with very low torque. This means that you must use a transmission / gearbox of some type to convert your power to a more useful state. Luckily, FIRST provides a drill transmission that you can use.
Do as much research as you can on the FIRST website where rookie workshops are archived. Also, look in the these CD papers area (menu item in orange band above) to look for drive train basics in some white papers.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 21-01-2004, 17:23
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Jesse,
Here's the easiest way to make a drivetrain using the Bosch motors:
- Use the drill gear boxes provided in the kit set to LOW gear.
- Use the motor mounts and couplers provided in the kit.
- Order two 6 inch wheels from skyway, and two casters.
- hook the output of the drill gearbox (in low gear, remember), directly to the 6 inch wheels (no need for more gears or chain). Be sure to support both sides of the wheels with bearings.
- Use the casters on the other end of the robot.
This setup will give you about 9 ft/s of speed. It won't be the best drivetrain in the world, but you can compete with it. If you want to be slower, use smaller wheels. I wouldn't go much faster, especially if you're using casters - it will be very hard to control.
The key here is that you can direct drive a wheel from the drill gearbox and be at a reasonable speed, but only in low gear. This will eliminate some complexity.
Good luck.
Unread 21-01-2004, 17:32
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Jesse -
Sent you a private message. Raul and Chris have very good ideas as well. Good luck.
-Mr. Van
Coach, 599
RoboDox
Granada Hills, CA
Unread 23-01-2004, 16:26
thanx for the help. i just wish that it was FIRST telling rookies this, and that they wouldnt put the pressure on kind veterans..... but thatnx for the help
Trade - have Bosch gearboxes, need motors Andy Baker Motors 0 24-01-2003 08:32
Bosch Aluminum Structural Framing Carl Owenby Technical Discussion 37 15-01-2003 21:11
Bosch motors archiver 2001 1 23-06-2002 23:08
Bosch Extrusion Tony G. Technical Discussion 4 11-01-2002 19:04
Bosch Extrusion Tony G. Technical Discussion 0 10-01-2002 10:26
