Go to Post Ok, I am geting flustered since I can't perform trigonometric functions with the tools FIRST provides. - jweric [more]
Unread 21-01-2004, 17:48
hedgehogger hedgehogger is offline
hedgehogger can only hope to improve
FRC default code
On the FRC default program is it programmed for one or two controllers to begin with???
-Hedgehogger
Unread 21-01-2004, 18:38
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: FRC default code
-Hedgehogger
Perhaps this little chunk of code from user_routines.c will answer your question:
 /*---------- 1 Joystick Drive ----------------------------------------------
  *  This code mixes the Y and X axis on Port 1 to allow one joystick drive.
  *  Joystick forward  = Robot forward
  *  Joystick backward = Robot backward
  *  Joystick right    = Robot rotates right
  *  Joystick left     = Robot rotates left
  *  Connect the right drive motors to PWM13 and/or PWM14 on the RC.
  *  Connect the left  drive motors to PWM15 and/or PWM16 on the RC.
  pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
Unread 21-01-2004, 18:41
jweric jweric is offline
jweric is an unknown quantity at this point
It also is able to do so with 2 joysticks as well, if you would look at where the PWM declorations above it a bit, I forget the lne numbers. You would use PWM outputs 1 and 2
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
2003 PBasic default code from Innovation First ttedrow Programming 0 06-01-2003 11:18
default code archiver 2001 2 23-06-2002 22:53
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
