Re: FRC default code
It also is able to do so with 2 joysticks as well, if you would look at where the PWM declorations above it a bit, I forget the lne numbers. You would use PWM outputs 1 and 2
| Problem with FRC Default code | AsimC | Programming | 2 | 11-01-2004 19:22 |
| How long does it take you to load the default code? | vegasmcse | Robotics Education and Curriculum | 10 | 03-11-2003 21:41 |
| 2003 PBasic default code from Innovation First | ttedrow | Programming | 0 | 06-01-2003 11:18 |
| default code | archiver | 2001 | 2 | 23-06-2002 22:53 |
| Rookie Programmer has question about the default code | DanL | Programming | 3 | 26-01-2002 19:59 |
