Go to Post Don't let Dean's homework assignment enter into the equation; his homework is about spreading his organization and has nothing to do with you doing what you want to do. - jonathan lall [more]
Unread 21-01-2004, 21:16
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
1 bearing is not enough.
The main reason the Globes need support is that they have only one bearing if you don't. The second bearing becomes the planetary gears on the last stage if you don't give it an external one. This is very bad for efficiency of the gearbox.
Joe J.
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
