Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 21-01-2004, 20:34
Alex N. Alex N. is offline
Alex N. is an unknown quantity at this point
Question Piston throw
Does the throw on pistons come in 1/2 inches: 3 1/2, 4 1/2, etc. when ordering from the manufacturer?
Unread 21-01-2004, 20:41
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
Re: Piston throw
I'm not sure if you are referring to the bore, throw or pistion diameter, but from the dimensions you just threw out, I would say you are interested in the stroke. The Bimba order form has varying stroke lengths from:
- 1/2" up to 10" throw for 3/4" bore
- 1/2" up to 24" throw for 1-1/2" bore
- 1/2" up to 24" throw for 2" bore
The intermediate sizes vary with the bore diameter, however you get the picture.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 21-01-2004, 21:19
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
Re: Piston throw
You can only order the strokes listed on the pnuematics order form found at the back of the pnuematics guide. The smaller stroke sizes go up by 1/2 inch increments and then just increase by 1 inch increments. Look in the back of the pnuematics manual for the specific sizes.
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
Don't throw away the messed up parts- Donate them to Timmy!! archiver 2001 0 24-06-2002 01:03
Piston power? archiver 2001 2 23-06-2002 22:51
