#31
Re: New Joysticks...Good or Bad Choice by FIRST?
#33
The directional pad on top of the joystick does take one of the analog inputs but there still is that second one you can use to make your wheel that was on last years joystick with a pot and a piece of wood or metal cut into a circle.
#34
To use a pot, all you need is to drill a hole. There's a litttle nut on top to attach it.
#35
Joysticks can we buy are own?
Can we buy are own joysticks or do we have to use the one's that FIRST gave use?
#36
you can buy your own
#37
It looks like the reason that FIRST went with the new sticks is that CH Products has discontinued the Flightstick. However, you can still buy the Flightstick Pro (the 4 button version of the Flightstick) for around $15 from places like PC Connection. I can't personally vouch that the quality of the Flightstick Pro is the same as the Flightstick, but it is ambidextrous and has been well reviewed.
For those of you who really want the old 2-button Flightstick, you can buy them for $30 from FlightSim Central. Last edited by ahecht : 23-01-2004 at 00:38. |
#38
just to let you all know, the directional pads on the top of the new sticks are called hats
personally i think that the new ones should be used for things other than driving. that way drivers can still use 2 joystick driving. |
#39
Looks like I got the last ones |
#41
The Joystick Does have p1_wheel but it only gives 5 values which we can use.
Leave centered p1_wheel = 45 push right = 202 push forward = 254 push left = 98 pull back = 149 These are approximate but you can make 4 decisions with these directions. This assigned p1_wheel control is between p1_sw_aux1 and p1_sw_aux2. David Bryan 818 |
#44
I wrote a function like this to find what buttons where what on the joystick (The same joystick first gave us.)
void Default_Routine(void)
if(!p1_x)
printf("p1_x\n");
if(!p1_y)
printf("p1_y\n");
if(!p2_y)
printf("p2_y\n");
if(!p1_wheel)
printf("p1_wheel\n");
if(!p1_aux)
printf("p1_aux\n");
if(p1_sw_trig)
printf("p1_sw_trig\n");
if(p1_sw_top)
printf("p1_sw_top\n");
if(p1_sw_aux1)
printf("p1_sw_aux1\n");
if(p1_sw_aux2)
printf("p1_sw_aux2\n");
#45
also, most of the values are not boolean values - that is, you can't really use an if statement to check them. for instance, the wheel will never show up, because it is a analog value from 0-255, but in the case of the hat it is never 0 - it's neutral value is somewhat above zero. Same goes for the joystick x and y axis - they are analog values from 0-255. Last edited by deltacoder1020 : 08-02-2004 at 19:23. |
| Vanilla Coke..good? bad? | A. Leese | Chit-Chat | 41 | 07-01-2004 00:15 |
| college counseling decides to help us... good or bad? | AlbertW | General Forum | 4 | 16-05-2003 15:14 |
| NYC Regional- Give me the good, bad, or ugly... | Rich Wong | Regional Competitions | 23 | 28-03-2003 17:56 |
| Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? | D.J. Fluck | Motors | 25 | 05-07-2002 16:40 |
| good idea or bad? | archiver | 2001 | 4 | 23-06-2002 23:08 |
