Go to Post Learn the ideas, look up the formulas. The other way round will drive you mad - Joe Johnson [more]
Unread 22-01-2004, 03:09
lasindi lasindi is offline
FRC #1164 (Project Neo)
lasindi is an unknown quantity at this point
bool Variables, Autonomous Mode
First off, can you declare bool variables? I tried to compile a boolean variable, just because 1 bit is more efficient than wasting a whole byte on a char or 2 on a short.
Second, I looked at ifi_aliases.h in the default code. At the bottom it uses a #define compiler directive to define the macro autonomous_mode. Could anyone show me how to use this? Would you use code like
if(autonomous_mode)
/* Do whatever I want the robot to do during autonomous mode. */
in the Process_Data_From_Local_IO() function user_routines_fast.c?
Thanks for the help.
lasindi
Unread 22-01-2004, 07:35
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: bool Variables, Autonomous Mode
First off, you can't just use 1 bit. it has to be in a structure with 7 others. If you want just 1 bool, I would use char and set it to 0 or 255
Unread 22-01-2004, 07:49
O-H
FRC #0048 (Delphi E.L.I.T.E.)
IFI set up a type structure called "bitid" for defining 1-bit variables:
Declare your variable:
bitid statusbyte
Define your macros:
#define gearstatus statusbyte.bit0
#define wingstatus statusbyte.bit1
#define wheeliestatus statusbyte.bit7
Seems to work fine.
Hope this helps.
Unread 22-01-2004, 10:00
Guest
Posts: n/a
By default, if you use a char to store "boolean" values, 0 is false and everything else is true. However if you have:
char boolVal=0;
boolVal=!boolVal;
// boolVal is now 255
Hence, you probably want to #define the following:
// Put this in a header file that every .c file accesses
typedef char bool;
#define true (char)(255)
#define false (char)(0)
Be sure to watch out for automatic cast of anything below above -1 and below 256 to an unsigned char.
Unread 22-01-2004, 10:02
Guest
Posts: n/a
And, there's no such thing as a real boolean variable in C, only in C++.
Unread 22-01-2004, 20:36
Thanks a lot for the help with the boolean variables. Could someone answer my question about using the autonomous_mode macro?
Unread 22-01-2004, 22:26
Guest
Posts: n/a
Where to put your auto code:
* FUNCTION:  User_Autonomous_Code()
* PURPOSE:  Executes user's code during autonomous robot operation.
* 	 You should modify this routine by adding code which you
*	 wish to run in autonomous mode. This executes every 26.2ms.
* CALLED FROM: main.c/main()
* PARAMETERS:  None
* RETURNS:  Nothing
void User_Autonomous_Code(void)
  while(autonomous_mode)
	if(statusflag.NEW_SPI_DATA)
		Getdata(&rxdata);   // bad things will happen if you move or delete this
		// autonomous code goes here
		Putdata(&txdata);   //even more bad things will happen if you mess with this
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
