Go to Post I wonder if we sang songs to Bill Miller if that would get TIMS opened sooner, like the way it worked to wring game hints out of Dave Laverly. - rsisk [more]
Unread 19-01-2004, 00:36
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Bumper Rule <R17>
The rule:
<R17> In order to help reduce the impact forces that the robot will experience during collisions with other robots,
teams may add external “bumpers” to the robot. If used, bumpers must satisfy the following constraints:
• Bumpers may extend outside the normal robot starting dimensions (in the horizontal plane) up to 4.”
• Bumpers must be located in a region from 2” to 8” above the playing field surface.
• Bumpers must not cause the weight of the robot to exceed the weight limit.
• Bumpers must be removable in order to allow the robot starting size to be easily measured during robot inspection.
• Bumpers must remain attached to the robot for the duration of the match.
• Bumpers and any bumper mounts that extend beyond the robot starting size may not contain “hard” materials such as metal, wood, or hard plastics. The definition of “hard” is one of common sense, i.e., if you can punch it and not hurt your bare hand, it is ok.
• Adhesive-backed tape may not be used to fasten bumpers.
Two questions on this one:
1. They say you need to have bumpers from 2" to 8". Can you have them to be more, say, from 1" to 10"?
2. Would a 1/16 polycarbonate panel be allowed as a bumper? It flexes, so it isn't exacly a "hard plastic".
Thanks
Unread 19-01-2004, 00:45
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: Bumper Rule <R17>
I would say no. It has to be from 2" to 8" for sure and using my teams bumper test from last year (If you hit it as hard a you could, would your hand hurt?) I would think polycarbonate would be to rigid.
Unread 19-01-2004, 00:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Since bumpers are going to be included in the weight, and its only 1/16", I dont see why you'd even call it a bumper. Also, to consider something a bumper, I think they want it to be soft, even if it gives a little. Im pretty sure you could punch Polycarb and it would leave your hand not feeling too great
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 19-01-2004, 00:53
Rasta Rasta is offline
Team Role: Student
Rasta is on a distinguished road
What if the bumpers are a "hard" material but is covered with a soft material?
Unread 19-01-2004, 02:04
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
On the bumper rules:
Definition [dictionary.com]
bump·erą
2. A protective device for absorbing shocks or impeding contact.
Question 1:
Rule: Bumpers must be located in a region from 2” to 8” above the playing field surface.
Question: What about 1" to 10"?
Answer: No, you become outside of the 2"-8" boundry intended by the rule.
Question 2:
Rule: ... The definition of “hard” is one of common sense, i.e., if you can punch it and not hurt your bare hand, it is ok.
Question: Would a 1/16 polycarbonate panel be allowed as a bumper?
Answer: When properly mounted, punching a 1/16" poly carb piece will hurt your hand when punching it.
This rule is INTENDED to allow people to have a soft foam-like material for TAKING a hit without a high impact load on both robots.
Unread 19-01-2004, 02:06
Gadget470's Avatar
A Fire Outside
That should answer your question. if it doesn't, the answer is no.
Unread 19-01-2004, 02:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It sounds like you are trying to make additions to your robot using the space intended for bumpers. Let's just remember to look at "the spirit of the rule." More often than not, you can answer your own question by following "the spirit of the rule."
Unread 22-01-2004, 22:03
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Bumpers should be a foam material, like a bike seat or something along those lines, that should be easily romoveable. You could velcroe them to avoid hard materials and have it easily removable.
Unread 22-01-2004, 22:15
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Team 384 (Tucker Tigers with Sparky) tried this a year or two ago (making bumpers out of curved 1/16" lexan), and I believe the final official ruling from a FIRST referee was that it was not legal.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 23-01-2004, 01:17
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Just keep in mind, the bumpers- ie: everything outside the competition size restrictions must be:
1) "punchable" ie: punch it as hard as you can anywhere, and not feel pain.
2) removable ie: easily removable, because you will have to remove them duing inspection for the inspectors to check the bot's actual size.
3) serve no function other than absorbing shocks abd bumps
my suggestion: pool noodles with velcro
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 23-01-2004, 09:58
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
A lot of team use the pool noodle design - it works well, and it's easily replaceable and cheap (so you can go through a lot of them without selling a kidney)
Benjamin Mitchell
Vex Robotics Competition team advisor (4 high school teams)
My Favorite rule. :) Useless member Rules/Strategy 15 01-03-2003 00:44
Rule C1 Justin Stiltner Rules/Strategy 9 05-01-2003 22:59
Do away with the 2-minute rule! archiver 2000 3 23-06-2002 23:17
1 coach rule Mike Soukup Rules/Strategy 14 07-01-2002 22:27
