Go to Post Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three. - Billfred [more]
Unread 22-01-2004, 19:13
duckshepherd's Avatar
duckshepherd duckshepherd is offline
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
duckshepherd is an unknown quantity at this point
Send a message via AIM to duckshepherd Send a message via MSN to duckshepherd Send a message via Yahoo to duckshepherd
Custom pneumatic cylinders
I heard somewhere that teams cannot fabricate their own cylinders for use with the pneumatcs for their robot. Our team wanted to make a cylinder for special purposes using PVC pipe. I looked through the rule book and I was unable to locate any rule that limited pnuematics use to Bimba manufactured cylinders. So are we or are we not allowed to make our own cylinders or even attatch a custom made device to the air tanks that requires air pressure to function?
-Jeremy Egger
Freshman-"Could you hand me that thing that makes that clickety noise when you turn it?"
Senior-"You mean the ratchet?"
No, I refuse. Wait, what? Did you say chicken and cheese? Alright then...
Unread 22-01-2004, 19:18
Re: Custom pneumatic cylinders
if you follow the 'can I use it' flowchart - when you get to pneumatics, the only thing you ARE allowed to use is standard cylinders from the approved supplier.
compressed air can be very dangerous. PVC pipes could go off like a pipe bomb if over pressurized, or if a fitting came off it would be like a bullet.
you are not allowed to make anything yourself that uses compressed air.
Unread 22-01-2004, 23:46
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
Alright, thanks. We we're trying to devise something that would telescope using pressurized air, but we were not sure if that was legal. I realize the PVC pipes could potentially explode if put under too much pressure, but we were going to limit the input pressure to extremely low anyway.
-Jeremy Egger
Unread 23-01-2004, 01:52
MV_Hirsch MV_Hirsch is offline
MV_Hirsch is an unknown quantity at this point
I don't know if this helps, but you can custom order 3 pnuematic parts from Bimba for free. We ordered ours on Friday and got them this Weds. (There should be an order form in the team manual)
Unread 24-01-2004, 15:33
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Where did you see the order from for custom cylinders???? I only see ones for pre-built ones.
- Thanks
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 24-01-2004, 15:51
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
That's exactly what he's referring to. In the 2004 Pneumatics Manual, they're referred to as "custom cylinders," even though they're prebuilt by the manufacturer.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 24-01-2004, 16:37
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Ive had PVC explode in my face at 100psi, wouldn't wish it upon anyone
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 24-01-2004, 20:39
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
I'd say that you should just use pneumatics as they are designed. cusom stuff will always be dangerous. I'd recomend that you find a mechanical solution to your problems, I'll even offer my help if you'd like to find an alternate solution.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
custom cylinders free? tenfour General Forum 2 29-01-2003 08:08
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Beatty and Kingman JAlpert Regional Competitions 51 08-04-2002 16:59
How many cylinders? Ben Mitchell Technical Discussion 13 17-01-2002 21:48
servos, chapulas, cylinders and Skyway...in other words... Jessica Boucher Motors 7 14-01-2002 19:36
