Go to Post I think we have officially reached the stage of having too much time on our hands. - Koko Ed [more]
Unread 22-01-2004, 13:45
yaman's Avatar
yaman yaman is offline
#0691 (Hart Burn)
yaman is an unknown quantity at this point
Send a message via AIM to yaman
Ordering the TSOP34840 Infrared Receivers
Hi everybody,
I'm trying to figure out how to order more of the sensors provided in the kit of parts--I couldn't find them at DigiKey, Mouser, RadioShack, or FutureActive. The supplier listed in the kit of parts is NewarkInOne, but they have a minimum order limit of 2,160 sensors.
I also tried searching google for the part number, but the only results were related to the FRC.
Has anybody else found a place to order the sensors from?
Thanks
Linux is the answer, now what was your question?
Unread 22-01-2004, 14:05
Re: Ordering the TSOP34840 Infrared Receivers
Originally Posted by yaman
Hi everybody,
Thanks
I just went to the Newark site and found single unit quantities for $0.78 each. You may have to contend with a minimum order but I didn't see any minimum quantity.
Unread 22-01-2004, 14:33
yaman's Avatar
#0691 (Hart Burn)
This is the part I found, here. Click on buy and it should show you a cart with 2160 items in it. I also tried calling them to order, but they told me that the minimum order still applied.
Unread 22-01-2004, 15:49
It doesn't seem to matter since they have 0 in stock and there's a 47 day lead time required.
We bought a dozen of the TSOP4840's from Newark rather than these.
Unread 22-01-2004, 15:50
I think I see the problem...
When I first downloaded the pdf the part number was TSOP4840 and that is the part I looked up at Newark. The TSOP34840 is the 3.3 volt power supply version. I believe the kit list may have a typo and it should really be the 4840 which is a 5 volt device, hence the ease in getting it from Newark (lead time on the 34840 was 47 days BTW) I will check into this and hopefully Kevin Watson will see the post and let all of know for sure.
Unread 23-01-2004, 02:10
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Sorry, just got back from a quick trip to the other coast.
Go ahead and get the TSOP4840 device. All of the development was done with this device and I know it works. Actually, I suspect that they're the same device. When they go to screening, the parts that pass at 3.3 volts probably just get dumped in the TSOP34840 bin.
-Kevin
Kevin Watson
http://kevin.org
