Go to Post Common sense can take you a long way!!! - ClintDog [more]
Unread 23-01-2004, 09:33
Electrical Engineer
Rookie Year: 1995
Re: Needing A header file
Originally Posted by jweric
the reason why I must use a float point is because I need to have correct values, saddly I cant do it any other way.
That is incorrect, you just are not aware of another way. Use fixed-point integer notation.
An example variable declaration could be:
integer max_v; // 2FX12 (0x1000 = 1 foot/sec)
In the above example, the resolution of the variable for maximum velocity is
0.003 inches per second and the variable ranges from + +7.99975 to -7.99975 feet per second.
Choose your number system with care and beware of overflowing variables in your calculations. Also realize that 0x8000 (negative zero) is not a number!
I assure you that the 2004 Bobcat has no floating-point variables and, sensor accuracy notwithstanding, the mathematical accuracy of our position is less than a tenth of an inch.
Best of luck,
Mike Betts
As easy as 355/113...
Unread 23-01-2004, 09:49
Jared Stofflett Jared Stofflett is offline
Jared Stofflett is an unknown quantity at this point
Send a message via AIM to Jared Stofflett
Can you give me a tutorial or example where I can learn more about this? ALl i've learned so far for decimal points is floating point data types. APpreciate any info.
Unread 23-01-2004, 09:59
Electrical Engineer
Rookie Year: 1995
Jared,
Unfortunately, everything I have is in books. You might try to google it.
Mike Betts
Unread 23-01-2004, 10:00
Guest
Posts: n/a
Floating Point Tutorial
Did a Yahoo search and got for "floating point" and got this tutorial web address: http://www.cs.utah.edu/~zachary/isp/applets/FP/FP.html
Most important thing about floating point:
DO NOT use unless absolutely neccessary. Any computation with floating-point data (like floats or doubles) is much slower than the same operation with integers (like chars, ints, and longs).
Floating-point data is different than other data because the number that the data itself represents is not directly stored. Instead, a mantissa, sign, and exponent are stored. This is sort of like scientific notation where you know the exponent which for the base 10 and the multiplier. In floating-point, you store every number as:
[sign] [mantissa] x 2 ^ ([exponent])
The 2 is not stored because it is the same for every number. Sign is 0 if the number is positive, and 1 if the number is negative (only one bit stored). Exponents must account for both negative and positive exponents, hence the exponent has a bias. This means that a positive number is added to all exponents in order to make every possible exponent positive.
Hope this helps!
Unread 23-01-2004, 10:25
Electrical Engineer
Rookie Year: 1995
Did a quick google and found this: http://www.embedded.com/98/9804fe2.htm
It should get you started...
Mike Betts
First Logo as a CAD file jrgrim12 Inventor 4 14-02-2003 11:42
The need for File Maker Pro 5 Dev. Edition archiver 2000 1 23-06-2002 22:50
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
