Go to Post I actually love and am very thankful for what all these amazing engineering role models put into this program year in and year out. - Bill Gold [more]
Unread 23-01-2004, 12:04
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Relationship between gear pitch and diameter
I found a reference that states the relationship between gear pitch and the outer diameter of the gear is OD = (No. teeth + 2)/pitch. Is that correct?
Unread 23-01-2004, 12:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Relationship between gear pitch and diameter
If it is a "standard" gear this is correct.
The standard addendem is (1/DP) or (1*module)
The OD is 2 addendems larger than the Pitch Diameter so that means the OD = (N/DP) + 2*(1/DP) = (N+2)/DP
Be careful about using this with smaller gears because they are often enlarged to make the teeth stronger. Even with larger gears, they are sometimes modified to mate with other gears (to make them quieter, stronger, or whatever).
Joe J.
P.S. Your question was not dumb.
Unread 23-01-2004, 12:40
None #0116
Thanks for the information. I want to add a castor coupled to an encoder to measure distance. The castor I'm looking at is a 6cm omni wheel. Since the castor is so small I have to gear it down before the encoder, at a ratio of 3:1, so that the shaft speed at the encoder is less the 300 RPM max for the part. I was planning on using a 24 tooth gear on the castor shaft and a 72 tooth gear on the encoder. The finest pitch I saw was 48, so they would be roughly 0.5" and 1.5" diameter each. Is this a resonable plan or is there a better way to do it? The shaft on the castor would be 1/4" and the gear on the encoder would be mounted directly to the shaft on a locking hub.
Unread 23-01-2004, 12:46
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Thumbs up Re: Relationship between gear pitch and diameter
There is an excellent section on the Standard Drive Products website regarding gear and drive components and the engineering behind them. Follow the link.......... http://www.sdp-si.com/D190/D190cat.htm
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 23-01-2004, 16:45
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Relationship between gear pitch and diameter
Though this is perhaps a tiny bit off topic... I've made a couple of webpages for Westside Boiler Invasion's KIP program (Knowledge is Power!) that are related to gears, how they work, and whatnot...
Here's a link with some bare-bones definitions:
Gears 101
And here's a link with some applications, and how you go about solving problems...
Gears 102
There's also a page on bending stress... mechanics of materials 102.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 24-01-2004, 04:14
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
just slightly more on topic, SDP-SI has a lot of gears and pinion shafts and other neat stuff. Specifically, if you need a finer pitch they go up to 120 pitch. Check'em out. SDP-SI
Machining/Engineering Question re: Pitch Diameter 157#1Driver Technical Discussion 4 08-01-2003 10:57
motor gear pitches archiver 1999 4 23-06-2002 23:09
gears....? archiver 2000 16 23-06-2002 22:58
