I was just thinking what everybody is think about this competition as far as feet per second? Are you planning to zoom (100 f/s), lumber ( 1 f/s), or average (
f/s) Anything you provide for me as afar as stats will be deeply appreciated ![]() |
Re: Average Feet per Second
I think it states in the rules that you can only go up to 10 f/s.....not sure on this one though.
sorry
sorry If I made it sound wrong, but what I am looking for is what your team is doing as afar as f/s for this years competition (like the average) not what the rules say is the max
p.s. The whole hundred feet a second thing was just a bad joke I guess we dont actually plan on doing that Last edited by MisterX : 23-01-2004 at 14:15. |
if your robot goes backwards as much as it goes forwards in a match, then its avearage pfs will be zero! :c)
BTW - does anyone know the speed you will get if you use the 12" KOP wheels and either of the two transmissions they gave us this year? (assuming you use the drill motors) |
#8
My rough (in my head) calculations say that you will go about 18 ft/s in low gear, and about 72 ft/s in high gear. I think you would want to gear it down a bit. -Chris |
#9
aye...our robot is using a 1 to 4 ratio with sprocket and chain...roughly, we should be going like 6 fps in low gear if I remeber the calcs right...
#10
FIRST gave a 10 tooth, 20 tooth and 45 tooth gears. If you use the 10 and the 45, you go 5.25 ft/sec in low gear, if my calculations are right with a 12" wheel.
#11
[edit] that is with a 7.5" wheel. You will go faster or slower accordingly, based on your wheel sizes. Cory Last edited by Cory : 23-01-2004 at 15:37. |
#12
I guess I got the calcs wrong then
#13
We're gearing for 7-9 fps this year; we've found that at much higher than 12 you start to lose control. |
#14
Using my whitepaper. (shameless plug). With the FIRST given 12in wheels, and a 10:45 sprocket reduction. I calculate: Drill Motor in high: 18 fps free speed (probably closer to 16.5fps) Drill Motor in low: 5.24 fps free speed (probably closer to 4.7fps) John Last edited by JVN : 23-01-2004 at 15:56. |
#15
Your bot 2 years ago (2002) went 13 FPS?????? I seem to recall it goign about the same speed as us which was about 6 FPS ![]() |
| Science jokes..... | Adam Y. | Chit-Chat | 20 | 10-12-2004 11:55 |
| Mad Dash for the Controls? | Madison | Rules/Strategy | 70 | 03-02-2003 22:50 |
| Crazy Idea, looking for comments | archiver | 1999 | 74 | 23-06-2002 22:56 |
| Scoring and Defense. | archiver | 1999 | 10 | 23-06-2002 22:44 |
| Seeding Calculations | archiver | 2000 | 50 | 23-06-2002 21:57 |
