Go to Post And please, never scorn a team that makes something outrageous, like a 4 speed 6 motor transmission. - Veselin Kolev [more]
Unread 23-01-2004, 14:10
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Beacon Code on Full Size RC?
Originally Posted by doy
i just tested it with
#define _FRC_BOARD
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
in Process_Data_From_Master_uP() and it gives the same error... should i have to #define that? if i dont, Generate_Pwms() requires 8 argument, and i dont know what the difference is.
I don't think that's right. Ex:
const int SomeVal = 321;
#define SomeAlias SomeVal
void SomeSub(void)
 if (SomeVal == SomeAlias)
  Code_Allways_Executes();
 if (SomeVal <> SomeAlias)
  Code_Never_Executes;
Which is compiled as:
void SomeSub(void)
 if (SomeVal == SomeVal)
 if (SomeVal <> SomeVal)
Get it?
Of course, I don't know all the ins and outs of C, so check the FRC default code.
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
