Go to Post "FIRST" is not a verb (yet - give us time, and we will see what happens). - dlavery [more]
View Poll Results: What motors do you use for the drive train?
CIM Motors 48 60.00%
Globe Motors 6 7.50%
Fisher Price Motors 10 12.50%
Drill Motors 59 73.75%
Other 6 7.50%
Multiple Choice Poll. Voters: 80. You may not vote on this poll
Unread 23-01-2004, 15:03
_GP_'s Avatar
_GP_ _GP_ is offline
AKA: Geoff P
#1277 (Crusaders)
Team Role: Student
_GP_ will become famous soon enough
What motors do you use to drive your robot?
I'm curious to know what other teams use as their main drive motor?
Our drive trains group wanted to use the drill motors, are these appropriate for the drive train? I had assumed they would use the big CIM motors, but they were worried about having to gear tehm down alot.
Thanks for any help
Unread 23-01-2004, 15:14
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: What motors do you use to drive your robot?
Last year, team 234 used a drill and CIM geared together and then geared way down so that we were slow, but deadly powerful. We geared a transmission in as well, but we ended up not switching gears. This same setup can be geared higher to be faster, or whatever you want.
Hope this helps
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 23-01-2004, 15:15
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
drill motors work fine and our team is using them again this year. It's crzy easy to do the drill motors simply because the mouting is prefabricated and the gearbox is something that has already been built. They're less of a drain overall on resources to use. Problems with the drill motors can be heat, our motors had major problems with heat because we ran one forward, one in reverse and the drill motor is not designed to go in reverse for any long periods of time. In time, one of our motors literally cooked, the back melting into a big mess of plastic and wires and all that. Heatisnks have been used before the cool the motors as have fans, though that does some to cool the motors, heatsinking is better.
The problem however with the Atwoods (the CIMS you were talkign about) is that there were not designed to run for long periods of time according to one of our mentors. They lack a cooling system, fans or even vents, for that reason. So when you run them, all the heat builds up insides of the motor and you end up setting yourself up for major problems. The other issue of gearing down is a valid one because a gear box (and a good one at that) is needed so that the drive train will not kill it self when it tries to inch forward...they spin I think at like 5000rpms or something like that when you hook them up to a battery. So you WOULD have to gear down the atwoods...and if the gear box isn't build lacking completely of movement, gears start seperating and thus, start stripping. It can be very bad.
All in all...stick with the drill motors. They're convenient and lack a lot of the problems that the Atwoods have.
Unread 23-01-2004, 15:22
MisterX's Avatar
MisterX MisterX is offline
Alumni
AKA: Mr. X
FRC #0521
MisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to beholdMisterX is a splendid one to behold
Typically we have used the drill motors for the drive train (like every past year) but this year we are trying something different and going with the Chipuau (Indian Outlaw, half Cherokee and Tompawa, there a one of a kind) But yes I definetly agree with the gearing down part; right know we are having to decide between two gear boxes that we might use.
Unread 23-01-2004, 15:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You might want to add Drills+CIM's.
As for your question, either one will prove to be fine. The Drills have a bit more power than the CIM's. They can be shifted using their transmission if you wish, and you already have the mounts and gearboxes if you dont want to make a chain and sprocket drive. People have voiced concerns with the integrity of the transmissions, but if you do it right, there wont be any problems. Also, the drills wont backdrive in their standard configuration, which may or may not be an advantage.
As to the CIM's, they are very easy to mount using the holes on the face. (10-24, I believe?) They still have a good amount of power, they don't overheat as often as the drills. They don't have an anti backdrive feature like the drills. They are also a bit heftier than the drills. One plus is that they spin at approximately the same speed forward and backward, unlike the drills, meaning that your robot wont drift to one side constantly.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 23-01-2004, 17:19
Atman's Avatar
Atman Atman is offline
"Bring the HAMMER" Go 364
AKA: Team Godfather
#0364 (Team Fusion)
Team Role: Driver
Atman has a spectacular aura aboutAtman has a spectacular aura about
Send a message via AIM to Atman
We used the Atwoods last year with our two speed transmission and they seemed to work just fine. We are probably going to end up using them again. We had them geared just right and they gave us the power to push anyone we wanted around in low gear running at 4fps. Even in high gear we were able to push a lot of the competition around at 10fps. No problems with overheating. In years past we did use the drill motors and they were effective.
Unread 23-01-2004, 19:07
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
In past years, we have gone with just the drills (2001, 2003). In 2002 we used the drills and the CIM's with a complex and heavy chain & sprockets transmission (We didn't have a machine shop).
Last year we just used the drills, shifted them with servos, and geared them down with chain. It worked well, although we had trouble overheating during the playoffs. We fixed that by cooling them with canned air (which is freezing cold).
It is much easier to go with just the drill motors.
-Matt Durstenfeld
Unread 23-01-2004, 19:11
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We used the CIMs the past 2 years, but we'd used the drills the previous 4 years. This year, we're using the drills and F-Ps together.
Jeff Waegelin
Unread 23-01-2004, 20:01
President, VEX Robotics, Inc.
We have used the drills and CIMs the last 2 years (actually, in 2002, we used the drills, CIMs, and Fisher-Price).
A little more information to help you out:
1. The drills this year (and last) are great for rookie teams due to the pre-fabricated gearboxes that come in the kit. The drills are also the most powerful motor by about 30% - 40%.
2. The CIMs are an excellent motor for driving because they are close to the same speed in forward and reverse and since they are a big motor, they dissipate heat a lot better than the drills.
The CIM motors are excellent for driving and we have never had a problem with overheating. We have never failed a CIM motor, but have burnt both the FP and the drill. The CIM motor is very robust.
3. I would only use the F-P if you are combining it with the drill or the CIM. I would not use it by itself.
-Paul
Unread 23-01-2004, 21:26
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Since our team has had success with the Bosch drill motors we keep using them year after year. We keep the transmission on them (with the pins removed) so we can have low and high range shifted by a small pneumatic cylinder. Our drive train has one mounted on each side and connected to the wheels with 35 chain. The motors are mounted opposite each other and one is connected to a jack shaft before the spocket to the chain so it will run the same direction of the other motor. This solves the problem of the robot "drifting" to one side when driving. They do get hot if they're driven long (like in a parade) but they don't get a chance to heat up during a normal 2 minute competition match.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 23-01-2004, 21:57
TheShadow's Avatar
TheShadow TheShadow is offline
Former Resident Rebel of 66
AKA: Alex '2.0' Uhlmann
TheShadow is on a distinguished road
Send a message via AIM to TheShadow
Last year we had too many issues with the drill motors. This year I think we're going with the Chippewas
Unread 25-01-2004, 13:50
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
We will use either the drills, or the CIMs. It all depends on what we use the other motors for *Wink*
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 25-01-2004, 14:02
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
Last year was the only year (that i know of) where we used the CIM motors, and we did have a large and heavy (and poorly constructed) gearbox. This year were reverting to the tried and true drill motors.
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 25-01-2004, 14:34
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Well the past 3 years we've used the drill motors (this year is no differerent). Last year though, we tried a dill/CIM combination which worked pretty well, although they added a lot of weight :/
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 25-01-2004, 15:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If my calculations are correct, the Chias have more torque at 40 Amps than the drills. But the drill does have a higher stall torque and is overall a more powerful motor.
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
