Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
Unread 20-02-2002, 15:27
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Post Re: Our highly sophisticated etching equipment
Originally posted by s_alaniz
Hi! Just wanted to promote our web site with our highly technical (homebrewed...)etching system for PC boards. Check out http://www.leopards57.com/
Team 811 designed a PCB, but we did it using expressPCB. For $59.00, you get three double sided boards in three days....shipping included!
Their layout software is a little clunky, but actually quite usable.
We did a through hole design...though they have SMT footprints also. (I found it would be hard to solder, so I went thru-hole)
What does your circuit do?
Our's measures the voltage across all circuit breakers so that we can monitor motor/battery current to protect the breakers.
-Quentin
Live free or die....
