FEA Modeling
Does anyone know of a good piece of FEA modeling software, perferable that interacts with Inventor, and a team could get their hands on?
We just want to see if our bot will explode or not. |
Re: FEA Modeling
FEA software tends to be rather excitingly expensive. And requires hardware capable of ludicrous speed to analyze anything more complicated than a single part.
To top it off, it's rather easy to misapply it and misinterpret the results if you don't know what you're doing. On the other hand, plain old hand calculations are cheap, and can probably get you enough accuracy to satisfy. If you don't know how to do it, find a MechE college student or a textbook on strength of materials. Half-priced books or Half.com should provide. If all that fails, then someone here should probably write up a brief whitepaper on rudimentary strength calculations. If I must recommend something, though, Ansys DesignSpace would probably work well. It appears that the educational edition, which has limited functionality, would run you $320. Last edited by Kevin Sevcik : 23-01-2004 at 12:47. |
Re: FEA Modeling
However a minor error like an incorrect end constraint or release can give you a very different answer. Depending on the program you are using, it can be hard to even find what you've assigned them to be. You kind of have to know what you're expecting before you look at the results to see if your model is behaving properly. That's how I find most of my mistakes. Quote:
. Quote:
FEA programs in general are by nature pretty user-unfriendly. They are used to produce mathematical represenations of how things might behave in the real world, if certain assumptions are in fact correct. Picking the right math and assumptions is an art unto itself. Go ahead and explore FEA, it is a useful skill and you might be one of those rare people with a talent for it. But don't bet the robot on the answers you get unless you have proffessional guidance. The textbook approach Kevin suggested is much cheaper and safer. I have dabbled in FEA for our robot designs. I might run a model or two after our robot is designed in an effort to catch any "Oh My God!s". But even so I will get guidance from one or more of the stress analysts I know at work. I don't do it enough to be proficient enough to get useful results in a hurry. |
Re: FEA Modeling
Neal was asking for an FEA package that would integrate with Inventor, though. This kind of FEA package rather stubbornly uses brick elements to represent the solid model and just throws a ton of computing power at the problem, unless FEA packages have advanced greatly in the last few months. But yes, the practical upshot of all this is that a good textbook or junior MechE is a rather lot cheaper and safer than FEA. Heck, most college students will probably work for food. I know I do. |
Re: FEA Modeling
The problem i was working on (a 2-speed tranny using overrunning clutches to shift) became a moot point once we actually got our hands on the clutches....
Thanks for all the advice anyway. |
Re: FEA Modeling
Just as a note for teams that want FEA programs, JL Analyzer 8.0 has a free version that isn't bad, I'm having trouble getting Inventor files into it, but its free. Go to www.autofea.com/Download-FEA-software.htm.
| What modeling program did you use? | archiver | 2000 | 5 | 23-06-2002 23:24 |
| Computer modeling of drivetrain and devices | archiver | 2000 | 1 | 23-06-2002 23:02 |
