Go to Post you are never an alumni of FIRST, you can always be there, mentoring, learning, creating. - KelliV [more]
Unread 23-01-2004, 11:56
Bob Steele's Avatar
AKA: Bob Steele
Re: first year team needs help
Hey guys!!!
The SINGLE THING that will help you more than ANYTHING ELSE in the competition is PRACTICE driving!! For a new team it is imperative to get the robot driving around and get your drivers to practice practice practice practice with it.. Don't worry about much else than a drive train and maybe something to push with. I guarantee you that you will have fun and contribute to your alliance every single time if you have a working drive train and the ability to scoot around the field with dexterity.
I have seen quite a number of robots that were fantastically designed fail in competition for many reasons. Get a solid robust simple drive train and drive the heck out of it. Make a barrier that you can safely push against or run into and ram it and push against it (within reason) Find out if your drive train and chassis will hold up or break it and then reinforce the areas where it is breaking.
PRACTICE
PRACTICE
PRACTICE
You will do fine!! I wish we were in New Hampshire... we would love to come over and help... but I am sure some of the other teams will!!!
You have joined a fraternity ... we are all brothers!!! (sisters too!!!)
Good luck and don't ever hesitate to ask for help from anyone!!
Unread 23-01-2004, 13:01
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
a few ideas regarding the plow design were memntioned...pneumatics for the ACTUAL plow could be bad because once they get bent, they become completely useless...and it's not that hard to bend something like that...it's also possible that you could start with the arm plow thing raised up at a 90 degree angle at the edge of your robot controlled by a pneumatic piston and drop them when you need to...if you build the arms long enough, you could also knock the 10pt ball...though arm stability can be a problem too...the pneumatic piston for that 10pt ball is a good idea...just shoot it out when your in proximity in autonomous...
Unread 23-01-2004, 13:04
a mentor at our team also mentioned that we could have built a simple drive train within a two week period of time using only the kit parts and then we'd have the following 4 to learn to drive it like no other. that seriously isn't bad advice to build a bot that owns in driving...just driving...
Unread 23-01-2004, 13:31
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
If you do decide on pnuematic anything, make sure it is not just the cylinder rod moving the part. If it could get hit, have the cylinder inside some square tube or extrusion. That way the piston rod does not get bent.
Unread 23-01-2004, 15:40
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Originally Posted by Air Soarer
... add on the fact the there are only 3 seniors(me being one), and we're the only ones who have any... skill, work ethic, or education in engineering. To put it bluntly, we're extremely far behind ... I have no experience in the competition, so I don't know what works and what doesn't.
I realize this isn't exactly what you're looking for, but as far as strategies goes, this one works pretty well.
The best advice I can give, for your team as a whole, is you're only as strong as your weakest player. If you've got someone on your team (a senior, freshman, whatever - it doesn't matter) that doesn't understand what's going on, or what the team is doing, then that's how much your team, as a whole, understands. Try to take the students who don't know what to do and teach them. Spend a couple of minutes showing them what you're doing and why you're doing it.
Another thing - pass on the knowledge. Say you're a expert on using the mill, the only one on the team who can do it, and the kid next to you can't tell the difference between a mill and a drill bit. Teach them. Take an hour and show them how to do square up a block of delrin. Once they've got that down, show them how to machine something a little more difficult. Not only will you have taught someone something new, but you doubled your machining capability!
Good luck!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 23-01-2004, 15:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Try to get in finished quickly. Practice is VERY helpful. If there is a scrimage in your area, try to have a working robot and attend it. If you can practice b4 day1 of the regional your even better off. A team with an awesome robot and bad driver will ALWAYS lose to a team with a working robot and a good driver.
Unread 23-01-2004, 16:00
Guest
Posts: n/a
Pneumatics best
As of right now, we have nothing. Building complex things is going to be virtually impossible, so please keep it simple. I have no experience in the competition, so I don't know what works and what doesn't.
Do you have access to precision machining?
If not, don't even try to do things with gears. I'd suggest making a simple two-wheel-drive drive train. Put two motors (maybe drill) in the front, and a wheel on each. You can try putting caster wheels in the back. For my (and my team's) first year, we tried welding gears to axles. We then chained the gears from the drill motors to wheels. However, if you don't have expert welders, such a set up is difficult.
About features, I agree that pneumatics would be the best feature to try. If you want to get custom cylinders ORDER THEM EARLY. The best part of pneumatics is that they are very quick to set up. In addition percision in calculations is much less important with pneumatics. Make sure you check the pneumatics manual from FIRST before you try anything. One con about pneumatics: they are binary. You can tell them to extend fully, or retract fully, not in between.
Good luck!
Unread 23-01-2004, 19:32
Air Soarer Air Soarer is offline
AKA: Chris
#1247 (System Failure)
Air Soarer is on a distinguished road
Send a message via AIM to Air Soarer
Thanks everyone for the ideas. I've gotten a lot of inspiration from this topic, and now I'm not so concerned. When I saw some robots from years past, I flipped. Now I know that it's alright if we have something much less complex than other teams. When I go in tomorrow, I'll bring up all the great ideas, and see how everyone likes them.
Unread 23-01-2004, 19:42
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Honestly for the auto mode, it might be easier to use the rotary pneumatic. Just have a piece of 80/20 sittin on that and when you get closer to the wall just have it flip out and pop the ball off.
Sure, it doesn't hook it onto the field, but it's simple and effective, which is by far the best strategy to go with.
I think KISS is so 1970's (you decide if the pun is intended), but I think KISES is (are) the future. Keep It Simple & Effective...Seriously (be nice ). Plus, KISES is the plural form of KISS...and we all know more is better
In any event, just do one thing well. You have many years ahead to build that ball grabber/king of the field/super fast/flying/burger flipping/Bush-impersonating robot or that flux capacitor concept you've had floating around for a while...
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 23-01-2004, 21:39
shyra1353's Avatar
shyra1353 shyra1353 is offline
Class of OT9
FRC #0771 (S.W.A.T. (St. Mildred's Women Advancing Technology))
shyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond reputeshyra1353 has a reputation beyond repute
Send a message via MSN to shyra1353
no matter what you build, because if you are far behind, remember to KISS or KISES and that if is very important to be able to do one thing and do it well.
Personally I think that the simplest design to build would be a square that has a bite taken out of it (so that it looks kind of like:
____
l___(
(sorry about the format .. i cant draw and upload a file right now)
but have a bit of a steeper plow kind of thing so that you can collect balls (obviously work out dimensions). and have a solid drive train so that you can run every match and are reliable .... a good human player would be an asset because getting the balls isnt worth anything if you cant shoot them in the goals .. and if you make sure the bot can go backwards, you are able to push the mobile goals from the back of your bot
and even if you arent ranked in the top 8th, you have a good chance of being picked for an alliance if you are reliable (i know im repeating myself)
2003 : 771 - SWAT - programmer
2004 : 1353 - The Gizmos - founder/team leader - mechanical head
2005 : 771 - SWAT - team manager and captain - design and construction member
2006: 771 - SWAT - mentor
2007: 912 - Iron Lyons - mentor
if you're going around in circles...then maybe you're cutting corners
aim for the moon and if you miss at least you will land amongst the starts
Email: underscore.asdf@gmail.com
My Website!!
Shirts available for trade: 2005 SWAT 771, 2004 Team 1353, 2003 FIRST Canadian Regional, and 2005 Greater Toronto Regional.
I am also interested in operator/safety captain badges, pins, or any other handouts your team may have given out that you would be willing to mail to Canada.
Unread 23-01-2004, 23:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
For future years(NOT THIS ONE) you could utilize the 116 gearbox, but you need some good machine tools to build it. It requires some practice to learn to build, but if you do it correctly, its worth the time, weight and effort. If you have the machinery, build one set over the summer and add it to the current bot and see how you like it to get practice and decide if you would wnt to use it future years. The adress for the white paper is below:
http://www.chiefdelphi.com/forums/pa...le&paperid=205
Unread 28-01-2004, 18:58
jneumiller jneumiller is offline
#0647 (CyberWolves)
jneumiller is on a distinguished road
Originally Posted by KenWittlief
also remember you will have an alliance partner in each match you play - you are almost certain to be allied with teams that can get the release ball, manipulate the 2X ball or climb the bar
so as long as you are able to do one function well, between you and your alliance, you should do great.
Ken:
You must have been at another FIRST competition last year...while you're correct, autonomous shouldn't be that hard, it sure looked like it was at the Lone Star Regional...probably the only thing that kept us in the hunt was that we'd noodled that one through correctly.
I hope you're right and we see alot more effective robots in the first 15 seconds, but I'm not putting a paycheck on it.
See you on the high ground or Atlanta,
Jim
Unread 28-01-2004, 19:43
Dick Linn's Avatar
no team (Synergy)
If you can drive, you can compete. Concentrate on a basic 2 wheel drivetrain (if it fits your strategy), get everything adequately supported and precicely aligned and practice driving. Some of the more successful teams have had the same driver for years, whatever the design.
This year, we're using the kit-supplied sprockets, some of the aluminum pillar blocks and a simple plate and shaft arrangement for mounting the drill motors just like our first year's robot (which was 75% wood). Although we have some other stuff, we didn't feel the need for a 4 wheel drive mechanism like last year (well, we're trying to do an add-on to help us get up onto the platform.... Both years we've competed, we've never broken a drivetrain component, nor needed any drivetrain adjustment whatsoever for the regional and a subsequent national event.
As a team, we're not terribly experienced and have minimal financial and machining resources, but we managed to be top seeded team going into the finals at the Richmond, VA regional last year. We work out of the school's wood shop and mostly do everything with saws, files and off-the-shelf parts. Our most sophisticated maching resource is a couple of regular drill presses.
Be clever, be persistent and try to keep it simple. You can succeed! Best of luck, and let us know if we can be of help.
Synergy
Team 975
Richmond, VA
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 28-01-2004, 20:13
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
first of all, welcome the the real world of student engineering, this is the life.
like the others said, you do not need to make complext mechanisms, our first year we were a box with wheels. While i did not take the time to read all of the above posts, here is something you can do to make up for lost time, we're going to be doing it ourselves. Hold a team meeting, tell the other members where you stand and he harsh, not degrading to the team spirit, but dont let them, or yourself just go eh, whatever, it'll happen sometime. Stay afterschool everyday possible, since our team is also an engineering class, we have alot of time. On the weekends, try to spend every waking minute working on the robot,we only have one more month - a few days, its crunch time. Try not to be a jerk of a team leader, but dont be weak person who will settle for less than the best that your team can do, be stern.
As for the robot, id say gathering balls is your best bet, the most complex you really need is maybe 2 arms on pneumatic cylinders, and that could be too complex if you are out of time, just try to make it functional, no one expects a first year team to beat a seasoned vetran, but it could happen.
an important thing is your tactics, we had a great robot last year, worked well and everything, but we did poorly because we had no practice time and did little prep work on plans for each match. take a look at the field drawings and plan out as much of the match as possible, due to our lack of planning last year, a 1st year team beat us brutally
AND DONT FORGET, this is meant to be FUN, not give us ulsers, though some of us designers have them every year, lol
hope this helped, have fun
Marcus - team impact 219
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
