Go to Post I've now read Dolly Parton's entire wikipedia page, which was not something I expected to do - WinterPoet [more]
Unread 23-01-2004, 19:51
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Line Tracking Times?
For those of you that successfully used line tracking last year, how long did it take for you to get your robot from the starting point to the wall?
Thanks,
indieFan
Unread 24-01-2004, 19:57
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Line Tracking Times?
Last year's times would be irrrelevent, last years rc was WAY slower. So if you went a decent speed, You would over shoot the line.
Unread 24-01-2004, 20:19
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It took us 15 seconds. I dont think anyone else did it faster (As always, correct me if Im wrong). The previous poster is right about the RC being too slow, at least to some degree. I think that at high speeds, you will still lose the line. It will be much better than last year, however.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 24-01-2004, 23:54
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
I already posted that our line tracking "worked", so I guess I had better chime in. But, as I posted before, we never used it in competition, and I don't think we ever timed it. I just know that it was way slower than the "blind swoop" we ended up using. (Probably someting like 6 seconds for the blind swoop, and, oh, maybe 12 seconds to follow the line?)
Unread 25-01-2004, 01:05
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
You mean...
You mean people actually did get to the wall before auto mode was shut off?
Our linetracking was way too slow. The new controller isn't going to help as much as to make a big difference in the total speed of the mode. Since this years line is mostly straight, however, if your drive doesn't arc, it should go somewhat faster than last years.
This year, we aren't using any sensory in auto mode, except for the current sensors, possibly, and a few small tidbits. We found last year that running a pre-programmed (or pre-driven) path without any error checking worked just fine, and this year it should work even better, since bots have a much lower chance of colliding before their destination.
Anyway, if you're going with linetracking, the code is very simple, and the sensory required isn't that much. If you want to improve your speed, here's a few tips:
*Use 3 banners, Left - Center - Right.
*Make sure your bot is almost always going forward. Here's a movement table:
LEFT. CENT. RGHT.
LEFT HL LL F
CENT LL F LR
RGHT F LR HR
Where: H = Hard, L = Light, R = Right, L = Left, and F = Forward
When no signal is present, I suggest you add in a small "buffer" into your program to look at the previous few seconds of input. If it sees that it had a signal on the right, and lost all signals, then it kows it needs to make a sharp sharp right. In all the movements, even hard turns, include a bit (25% or so at least) of forward motion. The only time you shouldn't go forward is when you lose the whole signal.
* Other sensory. The more sensory, the more data your bot has to compare against other data. Don't be afraid to add in other sensors in-combo to help you get where you're going. For example, someone who really wanted to be accurate in there path could use both the IR and Banner sensors to traingulate a better sense of positioning on the field. Gyros can be useful in calculating the robots position as well.
Look around, and check out your options.
Anyway, those are just a few things I remember we did and it helped quite a bit.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 25-01-2004, 01:44
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
This year's line sensor bots should be quicker than last year, because this year the line is mostly straight with two abrupt corners, instead of being mostly curved. As such, once you get to a straight section, once your bot it headed the correct direction, it should be able to zoom on until it hits the next corner.
The more line sensors you use, the better you can optimize the program, lessening your chance of "losing" the line.
I would use all four banner sensors in the following configuration (all located as far forward on your bot as possible): one pointing straight down at the line (should start right above the line), one to the left and right of the line (should never see the line, unless the robot is "losing" position on the line), and one in the center pointing at the line a foot or so ahead.
By using the fourth sensor to look ahead, you can prepare for the two abrupt turns (and if you add a switch to let your robot know which side it's starting on .... you can program it to go ahead and start turining that direction when it sees the turn coming up).
P.S. With all that said .... I still prefer dead reckoning.
Unread 26-01-2004, 07:33
AKA: Jamie Bliss
LEFT. CENT. RGHT.
LEFT HL LL F
CENT LL F LR
RGHT F LR HR
Huh?
Unread 26-01-2004, 10:15
Sachiel7's Avatar
AKA: Shayne Helms
Sorry for the 2 Ls in the table. Let me give you an updated one:
________LEFT CENTER RIGHT
LEFT_____HL____LiL____F
CENTER___LiL____HF___LiR
RIGHT_____F____LiR___HR
Where H = Hard, F = Forward, Li = Light, L = Left, and R = Right
This is a map of the sensor input. For example, when the Left and Center sensors are on, you move Lightly to the left. And, as I said, every bit of movement should have a certain percent of forward motion. So, when it goes lightly to the left, it really is going forward and left a little. The harder the turn, the less forward motion, but it should be there.
If you're still confused, let me know. These were just a few tricks we used last year to speed up our linetracking.
-=Sachiel7=-
Unread 29-01-2004, 14:42
WillyC's Avatar
WillyC WillyC is offline
"handy"
#1347
WillyC is on a distinguished road
Good call on the look-ahead sensor and the "what side of the field am I starting on?" switch, KevinB. We were also going to use the switch to let the robot know which side of the field it's starting on - left or right.
But we hadn't thought of the look-ahead sensor; thanks for the tip. Have you actually tried that look-ahead sensor? If the banner sends out a signal at a downward angle toward the front, it might not see the reflected signal. I tried this and found that 45 degrees from vertical is about the most you can angle it. Best to mount that look-ahead sensor out front, even in front of the two "straddling" sensors.
We only got two Banner sensors in our kits; did you order the other two? I was thinking I could snag two Banners from another team if they're not planning on using theirs...?
Unread 29-01-2004, 15:29
we had line tracking working well last year - and it took us about 5 seconds to get to the wall with it
we had 7 banner sensors on a bar about 2 feet wide.
funny thing is, the way we got our line tracking to work, we actually lost the line (went past it) which left the bot in a hard turn, and it would reacquire the line and then shoot up the ramp.
but we never used it in the competition. After we shipped the bot we realized it would be faster to use the gyro sensor, which we already had installed for closed loop steering, to integrate a compass heading, and to start off backwards and do a V turn.
this got our time to wall down to 3 seconds.
BTW - there was something about last years line following that made it very difficult - the half circle connected to a straight line requires accelerated acceleration to follow - in physics its called a jerk
the discontinuity from a straight line to a circle looks smooth, but its not. In fact, to follow the line perfectly last year would have required infinite acelleration (impossible)
and guess what, those bends in the line this year? same thing - you cant follow them perfectly, so your algorythm will have to take that into account - anticipate where you are going (straight, left turn, right turn....)
Unread 29-01-2004, 22:38
KevinB's Avatar
AKA: Alum
Oh ... for some reason I thought there were 4 Banners in the kit. Am I going crazy?
Unread 29-01-2004, 23:42
WillyC's Avatar
"handy"
#1347
Interesting point...
I don't think it's realistic (or at least necessary) to follow the line "perfectly". If you use two sensors, one on either side of the line, and space them out a bit (i.e. for a 2" line put the sensors about 4" apart), then the robot will "waddle" down the line. You know that when you get to the end of the line, the robot will be within 2" horizontally of it's target. It may be pointing at a bit of an angle, but it will be there. If you combine this with some other sensory info (turn counting, timing, gyros etc), you have a pretty robust system. But not perfect...
Unread 30-01-2004, 14:00
AKA: Jamie Bliss
Actually, I know of a method that uses only 1. Program the bot so that:
Sensor
vv Motor
XXX Left
DRK Left
LIN Right
DRK Right
LIN Left
DRK Left
LIN Right
DRK Right
LIN Left
etc...
Basically, it waves over the line. However, 2 or 3 are far more efficient.
Unread 08-02-2004, 18:48
lpramo55's Avatar
lpramo55 lpramo55 is offline
#0353 (POBOTS)
lpramo55 is an unknown quantity at this point
Send a message via AIM to lpramo55 Send a message via MSN to lpramo55 Send a message via Yahoo to lpramo55
we set up a test for our algorithm with this years rc but diff. gear ratio and drive wheels than this years robot will be. the test included a 90 degree angle and several other twists....granted it was about half the size of what it will be in competition i feel that it is much more difficult and didnt allow us to reach our full potential speed so our estimate, in conclusion, is that we will get there in 5-7 seconds
Unread 09-02-2004, 17:52
bob1million's Avatar
bob1million bob1million is offline
#0825 (Swivvey-gus Maximus)
bob1million is an unknown quantity at this point
Our team tried it with two sensors and we had the problem of over shooting the corners if we tried to have the robot moving at all times. If every time the sensor hit the line and we stopped and moved left/right motors it worked fine but it was kinda slow.
"Death smiles at us all, all a robot can do is smile back."
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
line tracking line BerserkerSpyke Rules/Strategy 1 18-01-2003 17:10
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
approach to autonomy Mike375 Programming 32 08-01-2003 14:04
emulationFIRST v0.04 Matt Leese Programming 7 09-07-2002 08:54
