no... this is in ifi_utilities.h:
#ifdef _FRC_BOARD
/* located in ifi_library.lib */
void Generate_Pwms(unsigned char pwm_13,unsigned char pwm_14,
unsigned char pwm_15,unsigned char pwm_16);
#else
void Generate_Pwms(unsigned char pwm_1,unsigned char pwm_2,
unsigned char pwm_3,unsigned char pwm_4,
unsigned char pwm_5,unsigned char pwm_6,
unsigned char pwm_7,unsigned char pwm_8);
#endif
so if _FRC_BOARD is defined, Generate_Pwms() takes 4 arguments, otherwise it takes 8. since the code initially had 4 arguments named pwm13, pwm14, pwm15, and pwm16, i assumed that the 4 argument call was the one that should be called, so i #defined _FRC_BOARD.
