Go to Post pit visitor: "Why'd you use #35 chain?" team member "less links to CAD...." - Aren_Hill [more]
Unread 23-01-2004, 23:50
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
Re: Effectiveness of Casters
Our team is going with two wheels in the back and skids up front. (Gives a new definition to skid steer- doesn't it ) The skids will be made of Delrin and give omnicaster like abilities with the neccessary machining complexities.
You might want to consider this method over the infamous castor, or you will have a story to add to it.
Unread 24-01-2004, 00:00
Will Hanashiro Will Hanashiro is offline
GM/Kettering Mentor
FRC #0322 (F.I.R.E)
Will Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really nice
Send a message via AIM to Will Hanashiro
i also would not recommend casters. four wheel drive is sufficient, six wheel drive may be going overboard. if you're looking for on-the-dime turning, why not try a trick wheel? for those of you who dont know, a trick wheel is a normal wheel, but with a whole lot of miniature discs going around the perimiter. the miniature discs allow the wheel to slide sideways, yet they provide sufficient traction for rotating foward.
West Michigan Regional #1 Seed
2006 GLR Motorola Quality Award
2006 WMR GM Industrial Design Award
Kettering University ME Class of 2009
Unread 24-01-2004, 00:08
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
When our team used casters on past robots, it worked well. We went in straight lines and didn't have any problems with them. I think the wobbly factor that some of you are talking about is maybe because there is not enough weight on the castor or it is not parallel to the ground. If you are going to go up the steps, then i wouldn't suggest casters, go with 4-6 wheel drive for that
Unread 24-01-2004, 00:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Search for "omniwheels" to get more information on such a "trick wheel"
Cory
2001-2004: Team 100
2006-Present: Team 254
Basic Drive Train Drawings Allison K Technical Discussion 13 21-11-2003 23:34
Casters should be banned! archiver 2001 10 24-06-2002 02:42
casters archiver 2000 2 24-06-2002 00:11
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
